Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Help
HomeSeer Help Help, How-to's and Documentation
Old January 19th, 2017, 11:48 AM
budejake budejake is offline
Seer
Fibaro Dimmer 2 & Scenes
Does the Fibaro Dimmer 2 work with Scenes?
I can't get it working but don't know if that's because it doesn't work - or if I'm doing it incorrectly as I've not setup scenes before.
I can setup a scene in Homeseer and give it a name - that works. I've enabled scenes on the Dimmer two but I can't see any way of triggering the scene? Am I missing an important part of config that links the two?
thanks
Old March 2nd, 2017, 06:09 AM
janjoh janjoh is offline
Seer
thanks
I have never gotten this to work, and I have received no helpful feedback from support.
But, i truly miss this functionality. And I would appreciate some official feedback.
Old May 17th, 2017, 03:01 PM
Qwerty1979 Qwerty1979 is offline
Seer
I would also like this to work.
I work as an electrician and have installed hundreds of Fibaro devices.
And was testing Homeseer to see if i could migrate some customers but if this dont work it will be impossible as i use switch 2 for scene activasion alot.
Has anyone got this to work?
Old May 17th, 2017, 04:11 PM
jmaddox jmaddox is online now
Seer Deluxe
I get the feeling that scenes are somewhat depreciated.
I've never used fibaro products. But I can tell you about my experience with my cooper 5 button scene controller.
To set up each button/add a scene I clicked the name of the scene/button in question on my device management list and went to the zwave tab.
From there I expanded the settings section.
Then I used the drop down list to pick a device, clicked the 'add' button to it's right; that moved it into the pane above it.
in the pane just above the drop down list, next to the device I just picked, I picked the command I wanted. finally I hit 'save scene changes'
Here is an example where I added 4 devices to a button. These devices are dimmers so I set the scene level ramp rate to 3 seconds to match my other lighting.
HS3 Pro on Hometroller S6 with Z-NET
Number of Devices: 143
Number of Events: 87
Plug-Ins: BLLock, DoorBird, Honeywell WiFi Thermostat, HSTouch Server, Restart, Z-Wave, EasyTrigger, PHLocation, Pushover 3P
External applications: Homebridge-homeseer, Geofency
Old May 18th, 2017, 12:26 AM
Seer
That looks great the problem is that i dont have that settings
Old May 18th, 2017, 12:29 AM
Seer
But when pressing the second button i get this in the log
Z-Wave ApplicationCommandHandler from node 4 HANDLING: COMMAND_CLASS_SCENE_ACTIVATION Frame(7)=1
Old May 18th, 2017, 06:24 AM
Seer
That way requires specific support for the hardware to be implemented by Homeseer.
Scenes is a standard across all zwave products. And any reason as to why central scenes is implemented in such a subpar way in HS3 escapes me.
Old May 18th, 2017, 01:24 PM
Seer Deluxe
Couple more thoughts based on the replies. 1) ensure you're using the child device and not the parent when you check the settings. 2) ensure the device has been added correctly using homeseer's add node function, you could try the Audit this node button, and/or Rescan. If you still have no child devices and settings doesn't populate, you may have to dig into the Associations and add them there.
Another thought, I saw this thread where they discussed adding a fibaro product using the Add Node Unsecure, you may wish to try that as well
https://forums.homeseer.com/showthread.php?t=182929
Homeseer can create/modify scenes which may also be helpful when setting up the associations. Plugins > Zwave > Scene Management
I found an old HS2 help file on the page, it's not changed that much with HS3
https://homeseer.com/support/homeseer...ave_scenes.htm
I also found a rather interesting post in the forums
https://forums.homeseer.com/showthread.php?t=138177
Even though it would appear that using associations to set up a controller is frowned upon, if it works it works. Some combination of creating the scene under scene management then associating it may be the key
If you do get things up and running, don't forget to let us know
Old October 30th, 2017, 06:33 PM
JQJQ JQJQ is offline
Seer
Homeseer and fibaro scene controllers
Is homeseer planning to implement this functionality?
Old November 9th, 2017, 12:20 PM
robyo robyo is offline
Seer
Fibaro dimmer 2 scenes not working
I'd really like to see HS3 support scenes with the Fibaro dimmer 2 as well.
Old November 10th, 2017, 05:13 AM
Seer
beta z-wave
I've heard back from support with some good news on this...
"Z-Wave update 3.0.1.154 just went live in the beta section, it includes added features for the Fibaro products that add more user-friendly support for scenes. I have not yet tested the update but it is available for everyone if you would like to give it a try. As of this update, no further work will be done for to the Fibaro dimmer 2 and switch 2."
Details here of the beta: https://forums.homeseer.com/showthread.php?t=175414
I've never tried the beta plugins.. do I simply disable the main Z-wave plugin and install the Beta? Will it maintain all of my devices and z-wave settings?
Old November 10th, 2017, 05:16 AM
Moskus's Avatar
Moskus Moskus is offline
OverSeer
Quote:
Yes. And yes.
But it is ALWAYS a good idea to back up your Z-wave controller AND the entire HS3 folder before you install beta updates (or any update).
HSPro 3.0.0.425, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Old November 16th, 2017, 08:19 PM
Seer
Quote:
Originally Posted by Moskus View Post
Yes. And yes.
Great that Homeseer implement this functionality.
Do I also need to delete and add the dimmer again?
I give it a try tonight, but I cant see in the log that a scene command is sent by the dimmer. I changed the parameter 28 to 1, but still no scene commands in the log.
I did a 'rescan' on the Fibaro dimmer2. Also no luck.
Did I miss something? Or how can I activate this funtionality?
thanks in advance.
Old December 15th, 2017, 11:30 AM
Stevemeck Stevemeck is offline
Seer
Keen to understand how we enable scene control from Dimmer 2 modules. I've looked through the forums and found a few questions asking the same thing but no answers!
I'm using release 3.0.1.159 (so after scene functionality was added) and have excluded and re-added nodes, non secure and secure. Enabled scene control with dimmer 2 (parameters 28 to 1).
I don't see any way to control a scene at the end of this. Any ideas?!
Old April 10th, 2018, 10:48 AM
Jon798 Jon798 is offline
Seer Deluxe
+1 here...
Would really like to make use of Scenes so I can reduce the huge number of lighting control events I have, but I can't find a way to trigger a scene from HomeSeer. Would it be possible to add a ZWave Event Action, or even a script function (via CAPI would be fine), so that we can trigger scenes without necessarily pressing a button on a scene controller?
Cheers,
Jon.
  #16
Old April 18th, 2018, 04:10 PM
Seer
Still really keen to answer this. I have multiple uses for scene control if we could get these working well.
Any bright ideas out there?!
  #17
Old April 18th, 2018, 04:15 PM
Seer
@RJH
"Changed in version 3.0.1.154 (Beta)
* Now only one EXE plugin for Linux and Windows
* Removed support for some older Z-Wave USB HID devices
* For Fibaro Dimmer2, added a scene activation device so events can be triggered on scene commands sent from dimmers "
This was specifically mentioned in .154, is there something we are missing on how to implement?
HTML code is On
Fibaro dimmer 2 HomeNorway HomeSeer Z-Wave Plug-in 14 November 20th, 2017 06:07 PM
Association between Fibaro Dimmer 1 & 2 Simonk HomeSeer Z-Wave Plug-in 0 March 3rd, 2016 05:18 PM
Fibaro dimmer association Simonk Lighting & Primary Technology Discussion 1 February 9th, 2016 07:04 AM
Fibaro Dimmer 2 sooty HomeSeer Z-Wave Plug-in 28 January 7th, 2016 11:13 AM
X10 scenes on Isteon 6-button keypad dimmer GaryP Insteon Plug-in (Mark Sandler) 2 May 15th, 2008 11:08 AM
