I have been testing this plug-in using HSTouch and it has been working quite well. I have a question.
If iTunes is not currently running as an application the HSTouch integration doesn't seem to operate. I manually have to start iTunes and and then cycle the iTunes DAAP plug-in.
I can add a button to HSTouch that will start iTunes and I suppose I can put the iTunes .exe in the Startup folder, but I was hoping that the iTunes dependency might be part of the plug-in's domain.
Am I missing something or do I have to have iTunes running as an application before iTunes DAAP will operate correctly?
