Lost all Insteon Communications
    I have a perplexing problem with 2 Fanlinc controllers and 2431u PowerLinc controller. A phase bridge is installed in the breaker panel. They have been intermittent at best over the last two years with typically all failed communication when 'test communications' was used.
    The fans are located in a high valted ceiling, so difficult to get to. Today, I decided to do a factory reset throughout and re-initialize the FanLinc controllers and the PLM. Uninstalled the two FanLinc controllers in Homeseer, reset the PLM (held set button in after pluggin in until beeping stopped) and hard reset the FanLinc (most difficult and it took many tries with the Factory reset pattern of pushes and beeps). The debug code below was just for the PLM. After a couple of hours of trials, the FanLinc responded to the manual Add process from the Insteon plug-in. Both light and Fan devices were created and show errors. The plug-in shows no communications between Homeseer / PPLM / Fanlinc.
    How do I determine where lies the problem? Is the PLM or FanLinc dead, or is there a link database error?
    Are there any tools for determining Insteon pathways and checking devices?
    House wiring is relatively new (25 yrs) and sound, so there will be no transmission errors. Lamps throughout the house are either compact fluorescent or LED.
    As the system has worked on and off, sometimes for a couple of days at a time, I think it is hardware?
    Any suggestions would be most appreciated.
    Steve
    Current Date/Time: 5/25/2018 8:07:00 PM
    System Uptime: 0 Days 7 Hours 17 Minutes 8 Seconds
    IP Address: 192.168.1.122
    Number of Devices: 250
    Number of Events: 121
    Available Threads: 400
    HSTouch Enabled: True
    Event Threads: 1
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Anti Virus Installed: Windows Defender
    Enabled Plug-Ins
    2.0.54.0: BLBackup
    2.0.26.0: BLRing
    3.0.6.35: Insteon
    3.0.2.215: Z-Wave
    Insteon Plug-in Error Log Generated 5/25/2018 1:02:33 PM
    -----------*Error Message*----------------
    Error: Forced error / log generation -- 5/25/2018 1:02:33 PM
    --------*Initialization Log*--------------
    5/25/2018 12:59:36 PM - Host System: 192.168.1.122 (55HomeSeer) 3.0.0.435
    5/25/2018 12:59:36 PM - Plugin HSPI_Insteon.exe version: 3.0.6.35
    5/25/2018 12:59:36 PM - Insteon Support library (Insteon.dll) version: 1.0.6.35
    5/25/2018 12:59:36 PM - RegisterCallback Completed
    5/25/2018 12:59:36 PM - Enter InitIO
    5/25/2018 12:59:36 PM - Enter InitPlugin
    5/25/2018 12:59:36 PM - Global initialization of plug-in required, starting up.
    5/25/2018 12:59:36 PM - Initializing Insteon hardware interface...
    5/25/2018 12:59:36 PM - In ProcessRawReceiveThread
    5/25/2018 12:59:36 PM - Initializing Interface...
    5/25/2018 12:59:36 PM - In PLMBuffer_ProcessBufferThread
    5/25/2018 12:59:36 PM - Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    5/25/2018 12:59:36 PM - ..Got Interface Response 02 60 3D 96 FA 03 15 9E 06
    5/25/2018 12:59:37 PM - ..Got Interface Response 02 60 3D 96 FA 03 15 9E 06
    5/25/2018 12:59:37 PM - RF PLM contacted on COM4 with an Insteon address of 3D.96.FA and firmware version 9E
    5/25/2018 12:59:37 PM - ResourceManager::RequestExclusive for Resource 1
    5/25/2018 12:59:37 PM - ResourceManager::RequestExclusive acquired for Resource 1
    5/25/2018 12:59:37 PM - Sending command 02 6B 48 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    5/25/2018 12:59:37 PM - ..Got RF PLM Response 02 6B 48 06
    5/25/2018 12:59:37 PM - ResourceManager::ReleaseExclusive for Resource 1
    5/25/2018 12:59:37 PM - Insteon hardware interface initialized.
    5/25/2018 12:59:37 PM - I/O (Insteon Protocol) Interface Initializing...
    5/25/2018 12:59:37 PM - In TransmitMessageThread
    5/25/2018 12:59:37 PM - Scheduled polling enabled.
    5/25/2018 12:59:37 PM - In CreateDevices
    5/25/2018 12:59:37 PM - Scheduled polling temporarily stopped.
    5/25/2018 12:59:37 PM - Reloading 0 Insteon device information tables...
    5/25/2018 12:59:37 PM - 0 Matching HS device records were found and updated for the Insteon device database.
    5/25/2018 12:59:37 PM - 0 matching HS device records were found and updated for the Insteon group database.
    5/25/2018 12:59:37 PM - Scheduled polling resumed.
    5/25/2018 12:59:37 PM - Exit CreateDevices
    5/25/2018 12:59:37 PM - I/O(Insteon Protocol) Interface Initialized.
    5/25/2018 12:59:37 PM - Exit InitPlugin
    -----------*Pre-Error Log*----------------
    5/25/2018 12:59:37 PM - Exit InitIO
    5/25/2018 12:59:37 PM - Waiting to initialize External Devices...
    5/25/2018 12:59:37 PM - Note: External device support script does not exist in the HomeSeer scripts directory.
    5/25/2018 12:59:37 PM - External Device Registration complete.
    5/25/2018 12:59:37 PM - Generic Event Raised: Ready for Registration
    5/25/2018 12:59:40 PM - Saved ini file. msecs=56
    5/25/2018 1:01:06 PM - Completely Reset Interface Selected
    5/25/2018 1:01:06 PM - Launching new BackgroundUpdate Thread with job type 12...
    5/25/2018 1:01:06 PM - In BackgroundUpdate Thread...
    5/25/2018 1:01:06 PM - Scheduled polling temporarily stopped.
    5/25/2018 1:01:06 PM - Now resetting your interface. This will take about 15 secs...
    5/25/2018 1:01:06 PM - ResourceManager::RequestExclusive for Resource 1
    5/25/2018 1:01:06 PM - ResourceManager::RequestExclusive acquired for Resource 1
    5/25/2018 1:01:06 PM - Sending command 02 67 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:True, NAK is ok:False
    5/25/2018 1:01:09 PM - ..Got RF PLM Response 02 67 06
    5/25/2018 1:01:21 PM - ResourceManager::RequestExclusive for Resource 1
    5/25/2018 1:01:21 PM - ResourceManager::RequestExclusive acquired for Resource 1
    5/25/2018 1:01:21 PM - Sending command 02 6B 48 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
    5/25/2018 1:01:21 PM - ..Got RF PLM Response 02 6B 48 06
    5/25/2018 1:01:21 PM - ResourceManager::ReleaseExclusive for Resource 1
    5/25/2018 1:01:21 PM - Now reprogramming the interface link database...
    5/25/2018 1:01:21 PM - Scheduled polling temporarily stopped.
    5/25/2018 1:01:21 PM - Refreshing Interface database with records for 0 Insteon devices
    5/25/2018 1:01:21 PM - A total of 0 records were programmed into the RF PLM Interface.
    5/25/2018 1:01:21 PM - Scheduled polling resumed.
    5/25/2018 1:01:21 PM - Reset and Reprogram Complete.
    5/25/2018 1:01:21 PM - BackgroundUpdate Thread Complete...
    --------*End Pre-Error Log*--------------
    --------*Start C:\Program Files\HomeSeer HS3\Config\Insteon.ini*--------------
    [Config]
    DetailedLog=1
    DisablePolling=0
    DoCleanups=1
    InterfaceCapability=5
    InterfacePort=COM4
    LastInterfaceAddress=3D.96.FA
    MaxHops=2
    NumDevices=0
    NumInterfaceLinks=0
    NumRetries=5
    SortDeviceLinks=0
    UpdateSliders=0
    UseLocation2=0
    WaitTimeout=3
    X10Enabled=0
    --------*End C:\Program Files\HomeSeer HS3\Config\Insteon.ini*--------------
    sounds like you have noise on the powerline or rf interfering with insteon signals.
    compact fluorescent bulbs generate noise that will interfere with insteon msgs on the powerline. try disconnect these bulbs and retest
    LEDs should be fine.
    other electrical devices can generate noise and impede signals as well.
    there are no external tools for testing pathways or signal
    there are several threads in this forum about tracking down noise
    Mark
    HS3 Pro 4.2.19.5
      Mark,
      Thank you for your response. I will reduce the number of compact fluorescent lamps where possible and see if that helps. Over time, the large fluorescent fixtures in the garage etc. will get replaced with LED's, but there are no immediate plans for this right now.
      All the PC's and electronics systems should not be contributing rf, as they are all running through UPS systems. Other than that, only regular household appliances on the 120v system.
      Will update post if I succeed and solve the issue.
      Steve
        Resolved
        After much playing around, it seems that the plm only likes the outlet next to the main breaker panel. Not sure why as there are no filters etc. on the sub panels supplying the rest of the house.
        At least it is working! and Plug In shows 100% for communications.
        Steve
          Steve,
          glad you were able to resolve the issue. if you run into this issue again, you might consider buying some filterlincs and putting them on the UPSs, your stereo equipment, etc.
          thanks for reporting back.
          Mark
          HS3 Pro 4.2.19.5
