I have been having a heck of a time trying to add back a SwitchLinc ToggleLinc V2 Relay after deleting it from my insteon setup after I suspected it was causing some issues in other areas, which I since realized it was not responsible for and have since fixed my original issue.
Now every time I try and add the switch back I run into a communication issue when trying to read the Link Tables from the switch.
I am using version 3.0.6.35 of the Insteon Plugin.
The switch is a: ToggleLinc V2 Relay 2466SW v6.6 (5816)
HS is running on a windows machine with:
Windows 10 Pro
Version: 1709
OS Build: 16299.431
I have tried many things, too many to list but they did include resetting the switch to factory defaults and trying to re-setup in HS, without success.
Attached is a detailed log from the Add Device job along with an image of the error that I get on the screen. After getting is error I press Continue and then press "Read Device Links and Settings" for the device but each time the job fails after reaching the set number of communication attempts.
There does appear to be some error from the Log:
Error in GetMasterDeviceInformation: System.ArgumentOutOfRangeException: Index and length must refer to a location within the string. Parameter name: length at System.String.Substring(Int32 startIndex, Int32 length) at Insteon.Support.Devices.DeviceRecordClass.IntializeLightingO ptions() at Insteon.Support.Core.InsteonModule.GetMasterDeviceInformatio n(String DevType, String FirmwareVer, String SpecialValues)
Can anyone explain what this error means or suggest some troubleshooting steps here, I am really at a loss.
Log155402.txt
Windows 10 Pro
Version: 1709
OS Build: 16299.431
Log155402.txt
