Originally posted by John245
View Post
Error after restart after update
Originally posted by John245 View PostThis is the text in the LOG
Mar-04 9:28:56 PM Error Device History: Device Location/Name lookup failed: Object reference not set to an instance of an object.
Mar-04 9:28:44 PM Error Device History: Device Location/Name lookup failed: Object reference not set to an instance of an object.
You can probably use some SQLlite tools to check and repair it.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Error on Restart 1.0.8
I really like the plugin. I am running HS3-PI2 and get this error on startup. I was on 1.0.6 and had the same error. I thought the new version may fix it.
But anyway, here is the error in the plugin.
WARNING: Failed getting Interface Status from Device History - the interface was not found in the list of active interfaces, the list may need to be refreshed.
Here is the error in the HS3 log.
Initializing plug-in(2): Device History Instance::Object reference not set to an instance of an objectSTACK: at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00000] in :0
If I disable the plugin and then enable it again then it works with no errors.
Let me know if you need any more info.
Originally posted by rich_jones123 View PostI really like the plugin. I am running HS3-PI2 and get this error on startup. I was on 1.0.6 and had the same error. I thought the new version may fix it.
1.0.9 was just put up and should address this, though it was a sporadic issue that depended on timing, so I can't prove it's fixed on my own system...
Sorry for the trouble!
Originally posted by rprade View PostI have had that on a couple of occasions, I would be interested if Shill has an idea how to fix it. I fixed it by backing up my config, deleting all of my devices, purging the database, stopping the plug-in, restoring the config and restarting the plug-in. I lost all of my historical data, but everything was happy again. It happened about July and December of last year. I think the database became corrupted.
Updated to 1.0.9. Issue was still there.
Selected "Device history\Device History Config", pressed
"save settings" and that did the trick.
John
