I'm setting up a new enviroment (after the PC that ran HS for years died...) anyway, I thought this would be a great chance to move from the PLC to the PLM becuase I was starting from scratch.
I have some devices on circut that I know has a some comm problems, but has been very workable with the PLC.
With the PLM it was VERY difficult to get my Keypadlinc connected to HS. Once I did get it registered I can communicate with it no problem. OK here is my problem...
Seems to be after a bunch of bad communication (trying to download lincs,etc) I then notice that Inseton is just hosed on any device. So, I restart HS. On closing HS it just hangs on last log entry of "Insteon shutting down". I then have to use task manager to kill HS. During Insteon init on startup, I get an error that it could not communicate to my PLM.
If I unplug the PLM then plug it back in re-start HS then everything is OK. This has happend a few times. I'm running PLM Rev 2.2 and Firmware 4A. Has anyone else seen anything like this? Am I on the correct rev and firmware?
Update - Looks like it does not have to be bad transmitions for it to lock up... It just keeps locking up after a few minutes of use. I have to unplug the PLM and plug it back in..... Very annoying. Should I go back to PLC before I get to far with my new installation? Does the SDM work on Vista?
Thanks.
Thanks.
