Originally posted by Bestgear
View Post
UltraCID HSPI For HomeSeer [NEW]
Originally posted by eole View PostThanks Ultrajones,
It works fine now
I'll be off for 4 days, and come back to you after that for another questions
Here are the first 2 :
How to have the caller name or number in a device to announce it when it rings ? (i've created an event on incoming call)
How to have a different way to see numbers (i would like XX XX XX XX XX) ?
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Skype installed and number field
2) Have skype installed so calling number comes up with Skype info and web field is to small to see mumber in detali log display. Can ths be made to grow and stick or somthing?
I don't understand this suggestion. Can you explain this further?
Ultrajones
Ultrajones
With the skype explore feature turned on it adds a skype call button to phone numbers when it see a phone number like in your caller log page. When it does this the field in your display is to small to see the number and the button. I was asking if the field in the display page could be wider. You could install skype and see it.
Thanks for expanding the Db on the caller name from my other question.
is there any chance this plug in will/can support gsm modems?
Currently i have access to three models, falcom 55, Siemens tc 35, and siemens m20.
Falcom comandset: http://www.falcomusa.com/downloads/S...and_set_01.pdf
Siemens m20 comand set (and probably tc35) http://www.cs.put.poznan.pl/msobczak/M20.PDF
Landline is not "the" thing as everybody i know and work with only uses cellular.
I'm using Stipus plug in and it is working great, but for two reasons it would be great if this would work as well.
1) I can have caller announcement for my wife as well, or
2) I can use this for my caller announcements and Stipus plugin for SMS sending
Originally posted by Ultrajones View PostUltraCID Version 1.1.3297.24956 was just posted which adds number format options and caller detail filtering by name or number.
I've just installed this last version (my license problem has been solved very quickly by Homeseer)
Name size can be longer ; that's fine.
I've changed number format to ## ## ## ## ## but the first "0" is not viewable in Caller Details. Even if I choose (#) # ## ## ## ## : in this case the result is () X XX XX XX XX but not (0) X XX XX XX XX
Another problem : the only way to view information in Caller Log is to select as first day a day where we can find a call.Last edited by eole; January 15, 2009, 02:00 PM.
Originally posted by Ultrajones View PostDoes caller ID in your country report both the caller number and name? If not, I may be able to provide an option for your modem to work when it reports the caller number ...
The CID info contaisnthe following:
04/01/2009 18:03:34 ~!~UltraCID Debug~!~Entered ProcessReceived() function with a string [TYPE = 01]
04/01/2009 18:03:34 ~!~UltraCID Debug~!~Entered ProcessReceived() function with a string [DATE = 0104]
04/01/2009 18:03:34 ~!~UltraCID Debug~!~Entered ProcessReceived() function with a string [TIME = 1804]
04/01/2009 18:03:34 ~!~UltraCID Debug~!~Entered ProcessReceived() function with a string [NMBR = 07534999999]
No option exists here to insert a name...
David---------------------------------------------------http://weather.penicuik.org
Another problem : the only way to view information in Caller Log is to select as first day a day where we can find a call.Plug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Originally posted by Bestgear View PostHi - sorry I did not spot your reply earlier.
DavidPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Originally posted by Ultrajones View PostOkay. I'll add an option so so modems that just report a number will work with the plug-in. I'll try to post an update tonight ...
Problem with spelling name instead of speeking it
I am using the HomeTroller and have a remote PC that is using the ATT voices. Everything has been working ok untill I purchased and installed your CID plugin. I notice that the person name is going out in upper case and this is causing the ATT voice to spell the name and not pronounce it. The audio on hometroller is ok but on the remote pc with ATT voices installed is where the problem is.
The question is there a way to issue the speak command in lower case. Even it I enter the name in lower case it saved in upper case.
Other than this problem everything else is work ok.
Bob
Originally posted by bobsegal View PostI am using the HomeTroller and have a remote PC that is using the ATT voices. Everything has been working ok untill I purchased and installed your CID plugin. I notice that the person name is going out in upper case and this is causing the ATT voice to spell the name and not pronounce it. The audio on hometroller is ok but on the remote pc with ATT voices installed is where the problem is.
Bob
Originally posted by Ultrajones View PostI noticed that most caller ID's I tested upper cased the name, so I followed that convention. I'll add a call to send the name though a string conversion function to proper case it prior to speaking. I'll post an update later today.
