Originally posted by FredrikKan
View Post
HS3 Scripting Documentation
I fixed the link to the PDF file.
Originally posted by FredrikKan View PostThe link to the pdf file seems to be broken again(?).
perl scripting in HS3 linux
I have developed a lot of perl scripts running in HS2 under Windows. I envisage to go to HS3 under linux and I'm busy to test all around H3/linux. When I put my perl scripts under the script folder, I don't see them when I want to start a script action of an event. Does it mean that perl scripts are not supported under linux ?
event scripting
I'm coming along a year later --- was Jim's request ever implemented? I tend to agree this is not an enhancement, but it is a request to put back something that was removed. I also created scripts in HS2 that have device triggers and conditions (along with script actions)-- looks like that is also not possible in HS3 (with scripting or a plug-in that is). It is not a "must have" for me, but it would sure save a lot of trouble and time over the long term if those capabilities that used to exist in HS2 were reinstated into HS3.
Pete
I found the help files:- http://homeseer.com/support/homeseer/HS3/HS3Help.pdf
- http://homeseer.com/support/homeseer.../scripting.htm
very useful, but besides from the Purpose, Parameters, Returns every script description should also have examples.
Like that for IsLicensed:
Code:sub main() If hs.IsLicensed then hs.WriteLog "Info","HomeSeer is licensed, thank you." else hs.WriteLog "Info","This copy of HomeSeer is not currently licensed." end if end sub
Make sure you take a look at the sample plugins, they have most of the commonly used functions in there in a working example.
Originally posted by ViperJD View PostI found the help files:- http://homeseer.com/support/homeseer/HS3/HS3Help.pdf
I am trying my hand at scripting, following some examples in the help file. When I tried to run the example for "GetDeviceByRef", I got this error:
Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\light control using.vb: 'Let' and 'Set' assignment statements are no longer supported.
Is this help file not current?
Originally posted by field888 View PostI am trying my hand at scripting, following some examples in the help file. When I tried to run the example for "GetDeviceByRef", I got this error:
If you declare DV as a DeviceClass you should be able to just put DV = hs.GetDeviceByRef(dvRef)
Originally posted by rjh View PostMake sure you take a look at the sample plugins, they have most of the commonly used functions in there in a working example.
Is it in the Help Files or somewhere else on the site?
Thank you.
thanks for the quick reply. It would be really nice to have an updated scripting help file. I've seen other posts relating to the same issue. Many people trying to learn, but no documentation with examples to help along the learning curve.
Can someone please post a link to the sample plugins that Rich is referring to?
Thank you
Originally posted by mrhappy View PostThe sample plugins are here http://forums.homeseer.com/showthread.php?t=160064 but I did not find them particularly easy to follow myself and contain a lot that you might not need (also very little commenting).
