THANKS !!! Looks Great
EnvisaLink DSC Plug-in - Feature requests
Device should show " Closed by Geary"
The possible status for a partition device are:
- Not Ready
- Ready
- Ready - Force Arming Enabled
- Armed Away
- Armed Stay
- Armed Away - Zero Entry delay
- Armed Stay - Zero Entry delay
- In Alarm
- Busy
So, I could add the "by user" suffix for all the Armed* status, but that doesn't make much sense for all other status. I think the best solution is to add a "User Access" device like in the HST plugin, to know the name of the user that last armed or disarmed the panel.
HS and Blade had a table in Setup to show user vs userid
DSC user # 1 = Geary ( needs to be user 1 or 16 = )
Regarding tamper and low battery:
As I said I can add tamper as a zone status. But for low battery, unless I missed something, the "Verbose Trouble Status" message you showed in your screenshot does not provide a way to know which zone has low battery, it's just saying that one zone has low battery but we can't know which one.
version 3.0.0.10
In version 3.0.0.10 avaible from http://board.homeseer.com/showthread...91#post1074491
you can assign several DSC user ids to the same HS user. In the config page Just enter the DSC user ids separated with dashes. For example in the screenshot below the user Test is assigned ids 1 and 40:
In this version there is also a new "User access" device that shows the name of the user (when available) that last armed or disarmed the panel
looks like DSC because of the flag set in setup automatically changes the user code from 16 to 1..etc
If I use the panel I get 1=Geary
If I use the FOB I get 16=Geary
If I just press the panel to go into armed, I get nothing, probably should default to "Auto" when no user # is found
see below for Sally (#2)
Looks like Mother / Daughter, changed FOB'sUbuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
DSC PGM triggers
Just wondering if pgm triggers could be added to this plugin? Back in HS2 I used the it-100 with the default dsc plugin which I could trigger pgm outputs. I connect relays to the pgms to control my garage doors via events that are manually triggered and I do not see this option in the events section. I know that thru the eyezon web portal I can trigger the pgms and everything works so it seems like it could be done? BTW good job on this plugin, it works really well and responds much quicker than using the it-100 thru the serial link. Well worth the $40!!!
Mark
Originally posted by MarkGr View PostJust wondering if pgm triggers could be added to this plugin? Back in HS2 I used the it-100 with the default dsc plugin which I could trigger pgm outputs. I connect relays to the pgms to control my garage doors via events that are manually triggered and I do not see this option in the events section. I know that thru the eyezon web portal I can trigger the pgms and everything works so it seems like it could be done? BTW good job on this plugin, it works really well and responds much quicker than using the it-100 thru the serial link. Well worth the $40!!!
Mark
I have added a "Trigger PGM Output" action in version 3.0.0.12 available from: http://board.homeseer.com/showthread...91#post1074491
PGM Outputs
Wow, I was not expecting such a quick reply along with the instant update!!! Good news I installed the update that you posted and it works!! If anybody needs any help setting this up on the DSC side let me know it is pretty simple. The PGM outputs are just like collector outputs where you connect a 12v relay to +12v and the ground to the pgm output and when it grounds out the relay it activates controlling anything you want. I programmed the dsc to toggle the relay for a couple seconds which resets it so it can be used again to close the garage door.
Thanks again!!!!
Mark
