Web Scraper Plug-in for HS3
    #46
    Hello Jason,
    Thanks very mutch for the URL's
    its working great just what i needed.
    Ed
      #47
      Originally posted by ESSCHENK View Post
      Hello Jason,
      Ed
      No problem. I added for my solar at home also.
      Jason
        #48
        Feature request:
        Would it be possible to create a link to the actual web page that I'm scraping.
        For instance, I'm scraping a school calendar for "today's events" if there were a goto link button next to the speak button I could click it and go right tothe whole calendar. or optionally turn the "today's events" string into a link.
        Just a thought.
          #49
          Originally posted by happnatious1 View Post
          Feature request:
          Just a thought.
          This seems reasonable. How about allowing for a HREF link in the status?
            #50
            I have added a new option in the ini file.
            Link=<link to be added to the status>
            example:
            [forecast]
            URL=http://forecast.weather.gov/MapClick.php?lat=32.9657005&lon=-117.1147095&site=all&smap=1&searchresult=San%20Diego%2C%20CA%2092129%2C%20USA
            RegExSearch=(?s)<li class="row-odd"><span class="label">.*?</span>(.*?)</li>
            RegExReplace=1
            RefreshInterval=60
            Enabled=true
            Debug=false
            link=http://forecast.weather.gov/MapClick.php?lat=32.9657005&lon=-117.1147095&site=all&smap=1&searchresult=San%20Diego%2C%20CA%2092129%2C%20USA
            This feature is available in V1.0.5.0 in the updater
              #51
              Originally posted by jrhubott View Post
              Sorry about the configuration file name change. I was getting the plugin ready for inclusion in the HS3 updater.
              I will have a PDF manual in the next version also.
              Is the manual in 1.0.5.0? Which folder is it in?
              Scott
                #52
                Scott
                It should install to the doc folder buy I just noticed it is not. For now you can get it out of the Install3 folder in HS3.
                Sorry I will look into why it is not being placed into the doc folder.
                Jason
                  #53
                  example:
                  [forecast]
                  RegExReplace=1
                  RefreshInterval=60
                  Enabled=true
                  Debug=false
                  Works great!
                  Thank you.
                    #54
                    Jason
                    Got it - cheers
                      #55
                      I think the hyperlink broke the speak button.
                      I get this in the homeseer speaker app.
                      Speak: <a href="http://www.smrhs.org/page.cfm?p=3030&calview=list&period=month">1st Day for All Students (12:30 Dismissal)</a>
                        #56
                        You're right. I will look into fixing that.
                        Sent from my iPad using Tapatalk HD
                          #57
                          Hello,
                          I have problem with a page with special characteres:
                          "precipitaciones d�biles. Temperaturas m�nimas "
                          What can I do?
                            #58
                            most of the scripts dont work ...
                            is this still active ?
                            HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
                              #59
                              The script is functioning ok but I have problem with special characteres as mentioned above...
                                #60
                                I haven't tried special characters but I will give it a try. Can you send me and example?
                                Jason
