I have 2 computers that I am upgrading to HS3. One is HS3Pro the other standard. Both HS2 versions had UltraWeatherBug working. I have added Ultra1wire3 on both and the Insteon plugin on both. They work fine. I purchased UltraWeatherbug3 for both and both show "True" on the Pulse API Pro , but neither can find any stations. I have read extensively on threads below but have not seen a resolution to this problem. Do you have one?
UltraWeatherBug3 can't find any stations
Originally posted by jfink View PostI have 2 computers that I am upgrading to HS3. One is HS3Pro the other standard. Both HS2 versions had UltraWeatherBug working. I have added Ultra1wire3 on both and the Insteon plugin on both. They work fine. I purchased UltraWeatherbug3 for both and both show "True" on the Pulse API Pro , but neither can find any stations. I have read extensively on threads below but have not seen a resolution to this problem. Do you have one?
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Resolved - stations showing up now
My API keys should have been working, but they were not. So I decided to get an entirely new account at http://api-portal.earthnetworks.com/user/8794/apps
using an entirely new name and email address. I got new keys and that made everything work just fine.
Weatherbug is changing service providers, because their current one can't keep up.
Ultra, should we see any issues from the change? (Other than their internal glitches?)HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Home Assistant 2024.3
Enabled Plug-Ins
I can no longer find any new stations.... nor am I getting any current weather from the old ones. According to the program, my keys are current, but no joy.
Anybody have suggestions about what is actually wrong? I'd rather not relive the hassle of trying to get new keys?HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Enabled Plug-Ins
Enabled Plug-Ins
You'll easily exceed the 15,000 per month query limit with 3 stations using the default settings. You'll need to either reduce the stations to 1 or increase the timeframe from every 15 minutes to once an hour.
OK, but it has been running in this manner for months..... maybe they just caught up with it.....HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Enabled Plug-Ins
