Any chance this will work on HS2?
HS3 MySensors.org plugin
My Sensor & Homeseer Linux (MAC)
Hi Henrik,
Thanks for the plug-in!!!
I'm new to Homeseer and My sensor and I'm trying to get as much done before my trial version runs out. I have followed the instruction you gave on the plugin for My Sensor but unfortunately, I don't see the gateway on the Manage page. Is there something I'm not doing right.
I've included a snapshot of the HS3 directory and marked in red are the item I've copied into.
My hardware:
I'm running HS3 Pro Edition 3.0.0.149 (Linux) on Mac and for the gateway I'm using an Arduino nano loaded with My Sensor serial gateway connected via USB to the Mac.
Can the plug-in work on Home Troller Zee ?
Jey
MySensor & Homeseer Linux
I manage to get the gateway and HS3 to communicate by rebooting both. Now, I'm still trying to figure out sensors and relays.... I don't know if my wireless works. Is there a way to test them and sensors?Last edited by jey.lites; February 24, 2015, 01:41 AM.
Go to hear that you got it working.
You can test the gateway and nodes (without HomeSeer) by connecting to the serial ports (115200/NL+CR) of the gateway and nodes. The gateway will send a 'startup completed' message when you connect to it. When you power up a node you should see some incoming messages at the serial monitor for the gateway.
HomeTroller Zee - it is not supporting 3rd party plugins to my understanding.
Best regards,
Henrik
Hi Henrik,
I did as you said and confirmed that the radio is working. My test includes a gateway and a binary switch sensor. I triggered the sensor switch and watched the messages come in on the serial monitor. Prior to that I received a start message from the gateway.
Question on HS3
1) Does HS3 identity sensors & relay nodes automatically or do I need to configure them?
At this point, I only see S_CONTROLLER but no Sensor Nodes.
Thank you.
Jey
What do I need
I have been lurking on this thread for a little while. This looks pretty nice. I think it looks fairly straightforward what to order-though it seems there are lots of options. Would anyone like to put a parts list together to add one lux sensor?
As I understand it there needs to be an arduino with a serial gateway and wireless module connected to the HS machine. Then for each sensor there needs to be a remote arduino with a sensor and wireless module.
Can I put more than one sensor on each remote arduino? Can any sensors be added to the arduino connected to HS?
Thanks for sharing this plugin. Hoping you add a sound level sensor by the time I get up and running._______________________________________________
I see a 3 in 1 temp humidity motion sensor described on mysensors.org. Would that work with the plugin? What about sensors on the gateway? Can we use multiple and remote instances of the plugin too? I ask because I have a few low power pc's around the house. I'm thinking of connecting an uno to each with a bunch of sensors and running a remote instance of the plugin._______________________________________________
On the mysensors site they quote 1000 meters for the default wireless option with an antenna. It's in their store. Would you need more than that?_______________________________________________
