Ok, after some research on this board, it seems many have found success using a ClearOne XAP800 with some Crown PZM-11 mics for HomeSeer Voice Recognition. I couldn't however, find clear documentation on wiring the PZM-11 to the XAP800 and to the PC. What I have done is the following, but could not get the mics to be recognized in HS3.
1. Wire the PZM-11 to the XAP800 input1 according to the image below (Using a Cat5 cable and using orange pairs for +, the blue pairs for -, and the green pairs for ground)
2. Wire a stripped stereo cable from the XAP800 output1 to the PC Line In (same connections to the Phoenix, Red to the left, Black in the middle and Shield to the right)
I made sure that the MICs & Output were not muted on the XAP800. When I connected the mic, I did see the signal meter drop to around -4 (from -80), so I thought I was on the right track. Also don't see the mic light on the XAP800 when connected.
Any help out there on this setup?
-Devon
-Devon
