Script for getting reminders for Next X Days
    Playing around with the scripting for BLReminders and trying to grab all reminders for the next 15 days. Can grab reminders for specific category using the following, but don't know how to modify to grab ALL categories.
    For Each remind in hs.PluginFunction("BLReminders", "", "GetRemindersForNextXDays", {15,"Household"})
    hs.writelog("Info", remind.Name)
    Next
    Tried several methods without luck. Help file says if I don't specify it will default to all, but have not been successful in that as it returns an error message. Help would be appreciated.
    Regards, Bob
    I will have to check the call and see. It has been a while since I looked at this.
    I am sure a call can be added if it does not do what you need
    I will confirm
    Cheers,
    Bob
      Thanks. Just so you are aware, I'm planning on writing a script that will populate a series of devices with "Days Till reminders" - be it a Holiday, Vacation, Birthday, etc. (excluding weekly reminders) that I will then use to display on my BetaBright sign (also using your plugin).
      Regards, Bob
        Bob,
        Any luck with this request or workaround that might be possible?
        Regards, Bob
          Log a help desk ticket on my site, then...
          Can you turn on debug logging in the plugin, then run that call, then turn off debug logging and attach the log zipped
          Cheers,
          Bob
            Try this:
            For Each remind As Object in hs.PluginFunction("BLReminders", "", "GetRemindersForNextXDays", new Object(){15,"Household"})
            Next
            Cheers,
            Bob
              Yes, this works but I'm looking to get all reminders for x days without a filter applied. How would I return all reminders?
              Regards, Bob
                Try this:
                For Each remind As Object in hs.PluginFunction("BLReminders", "", "GetRemindersForNextXDays", new Object(){15,"ALL"})
                Next
                Cheers,
                Bob
                  You the man! It works and much thanks
                  Regards, Bob
                    No problem
                    Cheers,
                    Bob
