We have the option to select Parent & Folder (bottom 2 levels of ISY folders) for Floor/Room. Would it be possible to have the option to select the TOP 2 folder levels as another option?
I have a folder for each floor (basement, downstairs, upstairs, outside, etc.) and for each room on that floor. But inside each room, I'd like to have a folder of devices for that room that are used in scenes & such, but you wouldn't need to turn these devices on/off directly (such as RemoteLinc buttons, Leak Sensors,Keypad Buttons, Door sensors, motion sensors, etc.) The Floor & Room would be visible, the folder(s) below that would be ignored. This is especially useful with HomeSeer Touch, so HS Touch doesn't display dozens of options to be controlled that you don't want someone to try to change.
Below is a general mach-up of the format...
Floor = Downstairs
Room = Living Room
Buttons (Living room remotes & Keypad buttons - Ignored by plugin & HS3)
Floor = Downstairs
Room = Living Room
