Does this plugin work on HS3 Linux. Plugin can't find the HS Data and config files that are in the download folder.
BLBackup Linux
Originally posted by ralnet View PostI setup the folder to be backed up. I would like to have the destination folder to be F:/Homeseer Backup. Will not let me set that folder. See attached image.cheeryfool
Google "raspberry pi samba". Here is one result that looks promising:
http://raspberrypihq.com/how-to-shar...-raspberry-pi/
Samba allows UNIX/Linux machines to "talk" PC file sharing language. I set up a Samba server on a SUN Solaris server, probably about 20 yrs ago. Before that, admins were installing an NFS client on each PC that wanted to access the files on the server, and having all sorts of problems. (NFS is the UNIX file sharing language). With one install of Samba on the server, all that went away and everything ran much smoother!
Another, admittedly low-tech (but simple) solution is a USB flash drive. My BLBackup destination for my Hometroller S6 is this:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
