Ring Count is Blank
    Ring Count is Blank
    I can successfully send an email with the following, except the "$$DTA:UltraCID3-Ring:" always renders a blank line.....
    You received a new incoming call from
    $$DTA:UltraCID3-Name:
    $$DTA:UltraCID3-Nmbr:
    $$DTA:UltraCID3-Attr:
    on $date $time
    Any thoughts?
    HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
    Home Assistant 2024.3
    Enabled Plug-Ins
    Hi. Caller rings are stored in the device value, so you'll need to use $$DVA:UltraCID3-Ring:
    Ultrajones
      Thank You! That fixed it.... You might want to make that change to your "Help" file, assuming I'm using the latest one....
      Enabled Plug-Ins
