Z-Wave PI PluginFunctions
    Is there a list of PluginFunction calls for the Z-Wave PI?
    What I want to do is test connectivity of a Parent device from within a plug-in.
    I don't seem to have uncovered anything from Google searches.
    Steve
    You can poll a device using this code here:
    PHP Code:
    Dim PollResult As New HomeSeerAPI.IPlugInAPI.PollResultInfo
            PollResult
    hs.PluginFunction("Z-Wave""""PollDevice", {dvRef})
    Substitute dvRef for the device reference of the device you are wanting to poll/
    Not sure if this is exactly what you are after, but hopefully might do the needed (or at least set you on the right track).
    Nicolai L
      PHP Code:
              PollResult
      Thanks Nicolai, that's a good starting point. I will do some experimenting.
      Are you aware of any other Z-Wave PluginFunctions? I have seen a thread about Configuration_Set and Configuration_Get but there must be others, some of which may be useful.
      Steve
        Steve
        Look at the Event Zwave Actions, you'll see them there (as well as others). Any reason you're wanting to script/code the actions rather than use an event?
        Z
          Z
          Not all are available as scripting calls (setting door lock codes as one example). I don't know of any more than the ones that are posted in this thread already.
          Cheers
          Al
            I want to call them from within a plug-in.
            Steve
              Steve
              Like Al says, it's a bit problematic. I've never seen a list nor been able to match up each Event Zwave action with a corresponding function within the Zwave plugin. You might give HST a call and see if they have that info available.
              Z
                Try importing the HSPI_ZWave.exe file into your VB project in Visual Studio. Then you should be able to browse the file and it might reveal more functions to you.
                Nicolai L
                  I've done that before and I haven't been able to find anything additional.
                  Cheers
                  Al
                    I've asked HST about this and they aren't interested in giving out any scripting references. I forget the what they said but wasn't the answer I wanted to hear.
                    Sent from my Pixel XL using Tapatalk
                      I am looking for the fuction to audit a network from ascript, to regularry check if one of the zwave modules is malfunctioning
                      Bart
                      Regards Bart
                      Win7 64Bit on Intel NUCI7 with SSD
                      HSPRO 3.
                      Devices; 1370 Events; 691
                      Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
                      Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
