Hi, do I need to loop through all devices to find the device by GetNamed info or could this be done by any direct method select to hs3 mssql database? I need optimize all steps in my project.
PHP Code:
Public Function GetKey(ByVal Parms As Object) As String
Dim dv As Scheduler.Classes.DeviceClass
Dim EN As Scheduler.Classes.clsDeviceEnumeration = Nothing
Dim EDO As HomeSeerAPI.clsPlugExtraData = Nothing
Try
EN = hs.GetDeviceEnumerator
If EN Is Nothing Then Throw New Exception("Failed to get a device enumerator from HomeSeer.")
Do
dv = EN.GetNext
If dv Is Nothing Then Continue Do
If dv.Interface(Nothing) IsNot Nothing Then
If dv.Interface(Nothing).Trim = "concerned interface" Then
EDO = dv.PlugExtraData_Get(Nothing)
If EDO IsNot Nothing Then
Dim api_key As Object = Nothing
api_key = EDO.GetNamed("api_key")
If InStr(api_key.ToString, Parms.ToString, CompareMethod.Text) > 0 Then
Return api_key.ToString
End If
End If
End If
End If
Loop Until EN.Finished
Catch ex As Exception
hs.WriteLog(" Error", "Exception in Find_Create_Devices/Enumerator: " & ex.Message)
End Try
Return "Not Found"
End Function
