Panel Configuration Info Disappearing
    #16
    Originally posted by avpman View Post
    Which ports do you need forwarded to the unit (80 and 21?)
    Use 22 for SSH
    80 is fine for web.
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      #17
      @Rob-AVPMan...
      You can if you want just keep SSH open and proxy the web interface (modify your browser to using loopback address and proxy port).
      IE:
      ssh -D 8888 rootoruser@WANIPADDRESS
      Change the default autoproxy on your browser to loopback with port 8888.
      [ATTACH]60986[/ATTACH]
      Then just browse to the local HS3 IP / port remotely. This way you only keep one port open. (also modded sshd / iptables / longer password on host because of some brute force attempts)
      Auto mator
        #18
        Originally posted by rmasonjr View Post
        Use 22 for SSH
        80 is fine for web.
        Tried to PM you with login info, received error:
        rmasonjr has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
          #19
          Yeah, better to email me at : robmasonjr67 at yahoo dot com
            #20
            Sent
              #21
              I think Jim is good to go. I SSH'ed into his Zee and found that he had a /usr/local/HomeSeer folder that was under /usr/local/HomeSeer
              I removed that folder and all HAI-related plugin files and re-installed. It seems to be working correctly now.
              Jim - yell back if you need anything else.
                #22
                Kudos to rmasonjr for going above and beyond to fix this.
                Just as an aside the problem happened after I cleared and did a factory reset on the ZEE. Likely a problem with the HS recovery firmware. If I'm brave enough I may try the restore again and see if I run into the same problem. Or maybe I'll just report it to HS so they can try and replicate.
                  #23
                  Good news Jim!!!
                  @Rob; so then HomeSeer was installed in two directories?
                  IE: /usr/local/HomeSeer/usr/local/HomeSeer
                  Auto mator
