Go Back   HomeSeer Message Board > Internet or Network Related Plug-ins > Internet or Network Discussion
Old June 27th, 2017, 05:00 PM
Jakob.Sand's Avatar
Jakob.Sand Jakob.Sand is offline
Seer Deluxe
What is my IP plugin? does it exsist?
My ISP has started to shift my external IP address. I therefore need to send my new IP address via the pushover plugin.
Does anybody know if there is a plugin that can grab my external IP? and even better can detect an IP chanoge and trigger an event based on the change?
Best,
Jakob Sand, I automate everything!
Old June 27th, 2017, 05:04 PM
zwolfpack zwolfpack is offline
Seer Master
You can get it from here: http://checkip.homeseer.com:8245/
Old June 27th, 2017, 05:17 PM
Jakob.Sand's Avatar
Seer Deluxe
Quote:
ok how to I then grab it and sent it for instance via Pushover plugin to my phone?
Old June 27th, 2017, 05:57 PM
mrhappy mrhappy is offline
OverSeer
I can potentially put this back in the Pushover plugin, the plugin used to have a replacement variable that put the external IP in from a call to hs.wanip. This call was causing all sorts of issues (blocking the messages being sent) for reasons not entirely clear.
I can look at grabbing that data from that IP and enabling that if you were interested.
Old June 27th, 2017, 06:38 PM
fungun's Avatar
fungun fungun is offline
Seer Master
There's this too.
https://forums.homeseer.com/showthread.php?t=102645
Tim
FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
“No, I’m from Iowa. I only work in outer space.” – Captain Kirk
Old June 27th, 2017, 06:44 PM
OverSeer
Quote:
I've put version .32 of the Pushover plugin in the updater, it fixes the replacement variable to get the IP from this location. If you include %HSWanIP% in any of the fields then it will pass the external IP along to the message for you, the Plugin help file has other replacement variables if you needed.
HTML code is Off
ERRO Calling SetIOMulti in plugin Arduino Plugin:Object reference not set to an in fvhemert Arduino Plugin (3P) 5 April 28th, 2017 10:15 AM
Port Forwarding...Can homeseer and a DVR exsist on same network? Automate_It HomeSeer General Discussion Area 2 August 18th, 2008 08:47 PM
Upgrade procedure for ACRF plugin from W800 free plugin htsource ACRF Processor (3P) 14 January 26th, 2006 11:21 AM
Switch-to messages, plugin restart, and plugin startup Michael McSharry Plug-In Development 4 January 27th, 2003 11:20 PM
