I've created a utility that grabs a CCF file, pulls out the IR Codes, converts them into Global Cache format and writes them to the Global Cache IR file.
I was then going to add them to the IR-Labels.ini file, but was wondering:
A) is this the right approach, or are there other library files I shd be thinking about?
B) is homeseer limited to 999 or code slots?
C) if I change the ir code slot number of a label (so long as it stays in sync with the global cache data files), will there be other unintened consequences?
The idea is to bulk copy IR commands rather than do it button by button. If anyone had a better idea, or if this has been done before, please let me know.
I wish hs had a pre existing ir code library or a facility to create a user generated one!
S.
S.
