Description
UltraCID3 is a HomeSeer3 plug-in that allows you to use HomeSeer and an inexpensive USB or PCI modem to log callers to an underlying database. The plug-in also supports triggering HomeSeer events based on the name, number or attributes of a received call.
How It Works
Example Usage
Change Log
Version 3.0.5323.3261 - Released July 29, 2014
Version 3.0.5341.13686 - Released Aug 16, 2014
Version 3.0.5440.34301 - Released Nov, 23 2014
Version 3.0.5467.17807 - Released Dec, 20 2014
Version 3.0.5528.34367 - Released Feb, 20 2015
Version 3.0.5723.37761 - Released Sep, 2 2015
Ultrajones
How It Works
- UltraCID3 listens for incoming caller ID (caller identification, CID) messages from your PCI or USB modem and inserts the data into an underlying database.
- HomeSeer events can be created to trigger based on the name, number or attributes of a received call
- Logs all calls and associated caller ID information to an underlying database.
- Override the caller Id name so you can identify a caller by their full name or other alias.
- Specify caller attributes such as block, announce, telemarketer, family, friends, business, etc.
- Trigger a HomeSeer event based on the ring count or an incoming call.
- Drop an incoming call after the first ring based on caller attributes.
- Error Try/Catch logic to ensure plug-in doesn't fail with an unhandled exception.
- Multiple threading allows UltraCID3 to process caller ID events without disrupting the performance of HomeSeer.
Example Usage
- Use plug-in UltraCID3 to speak the name and/or number of an incoming caller.
- Use plug-in UltraCID3 to generate an e-mail notification whenever you receive an incoming call.
Change Log
- Caller ID attribute HomeSeer device is updated before caller ID triggers are checked.
- The Caller Id Last Change device value is no longer updated when HS3 restarts.
- The plug-in web pages now use HomeSeer jQuery controls instead of ASXP.
- Fixed issue with Caller Name field.
- Fixed edit issue with Caller attribute field.
- Fixed display issue when telephone numbers start with a leading 0.
Ultrajones
