I installed a HomeSeer 3-way switch setup in my living room this past December. It worked perfectly for the past 4 months. I use SmartThings as the hub.
This past weekend, the 6 recessed lights blinked a few times and then went out. The lights no longer turn on. The HomeSeer switches' LEDs light up but the recessed lights stay off. SmartThings can still see the lights and it thinks they're turning on/off.
I tested the bulbs in a simple plug-in lamp and they work fine. I also swapped out the bulb for an LED bulb and the HomeSeer couldn't turn it on.
Where should I start my diagnosis?
