A few weeks ago my HS on my android would no longer connect. I'm not aware of any changes and have uninstalled the app and reinstalled it a few times, changed passwords etc. The app connects but will not communicate.
From my log file:
Oct-05 12:55:37 PM HSTouch Server Client has DISCONNECTED.
Oct-05 12:55:37 PM HSTouch Server Client (192.168.0.147/43184) has raised LineDisconnected or was forced closed.
Oct-05 12:55:37 PM HSTouch Server Warning Client dropped connection 192.168.0.147/43184
Oct-05 12:55:37 PM HSTouch Server Opening connection from:192.168.0.147/43184
Oct-05 12:55:36 PM HSTouch Server Client has DISCONNECTED.
Oct-05 12:55:36 PM HSTouch Server Client (192.168.0.184/1704) has raised LineDisconnected or was forced closed.
Oct-05 12:55:36 PM HSTouch Server Warning Client dropped connection 192.168.0.184/1704
Oct-05 12:55:36 PM HSTouch Server Opening connection from:192.168.0.184/1704
Oct-05 12:55:36 PM Info The user xxxxx@xxxxxxx.net, was added to the system due to a login from HSTouch through MyHS. This feature may be disabled in setup.
I'm running HomeSeer Version: HS3 Standard Edition 3.0.0.357 (Windows) on a Hometroller and Android version: 1.0.160
I can connect with no problems using my laptop through a hotspot using MyHS.homeseer.com
Any fresh ideas would be greatly appreciated.
Well, HS update .368 made the problem go away!
All is well again. Permanently I hope.
Worked great this morning, nothing changed here, stopped working and back to "connected but can not communicate".
Am I the only one having this problem?
From my log file:
