The system is apparently interpreting Unit Code 11 as Unit Code 1.
Wrong Unit Code Detected
http://jvde.us/forum/index.php?topic=59.0
This is a bug in the Linux version of the CM15a plugin, not the hardware. When evaluating triggers 2 digit addresses are incorrectly truncated to a single digit.
I will look at this issue along with the 'All Units' issue you reported previously when I am able.Best regards,
-Mark-
Originally posted by mfisher View PostThis is a bug in the Linux version of the CM15a plugin, not the hardware. When evaluating triggers 2 digit addresses are incorrectly truncated to a single digit.
Yes, sorry. Currently working on getting the HS3 X10 plugin running under HS4 and will then incorporate my findings, and this fix, into the Linux CM15a code.Best regards,
-Mark-
I just posted beta version 3.0.0.6 to the beat release sticky in this forum that addresses the 'wrong unit code' issue. It also adds support for running under HS4. Please create a new post if you have nay issues with this version.Best regards,
-Mark-
