Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > MCS Plug-Ins and Scripts > xAP > xAP Library
xAP Library Library area for plug-in nodes. Use the discussion area to discuss these - posting here is only allowed by the moderator.
Closed Thread
Old February 4th, 2005, 02:14 AM
Michael McSharry's Avatar
Michael McSharry Michael McSharry is online now
xapmcsTemp0x - Temp05 v4, v5 / Temp08 1-Wire Interface xAP Node
Component of mcsEnvrionment plugin to provide 1-Wire sensor data from Temp05 or Temp08 onto the xap network. Supports BSC 1.3 schema.
Uses sensor identification conventions of mcsTempeature and mcsEnvironment.
VB6 Version 1.x
PR 1 1.1.0 Report BSC events on change rather than periodic BSC info
PR 2 1.3.0 input.state & output.state changed to input.state.1 & output.state.1
PR 3 1.3.0 Handle "M" and "P" in Temp08 DIS
PR 4 1.3.0 Allow "L" to be lightning or water flow count
PR 5 1.3.2 Fix "L" device type default for all DS2423 sensors
PR 6 1.3.3 Unwildcarded BSC query and cmd not recognized
PR 7 1.3.4 Humidity displaytext does not have HTML formatting
PR 8 1.3.6 Add UI similiar to xapmcs1Wire
PR 9 1.3.6 Add Temperature Discrete type
PR10 1.3.8 Change index accounting
PR11 1.3.9 Baro rate calculation gives object required error
PR12 1.4.7 Add logic to manage a changing IP address
PR13 1.4.7 Display Wind Direction icons as N.gif rather than 0.gif etc.
.NET Version 2.x
PR14 2.0.0.0 Initial .NET version
PR15 2.0.0.1 Improve recovery of dropped IP connection
PR16 2.0.0.2 Ignore Humidty/Baro reported as voltages
PR17 2.0.0.6 IP/Serial connection that does not exists hangs program
PR18 2.0.0.24 IWIO and related support update
PR19 2.0.0.25 1.5 second delay in commands with space (e.g. TYP02 O)
Console Version (Linux or Windows) http://mcsSprinklers.com/xapmcsTemp0xConsole.zip
http://mcsSprinklers.com/xapmcsTemp0xNET.zip
Old May 21st, 2005, 06:09 PM
Temp05/08 and 1Wire xAP nodes reporting change
Both the Temp05/08 and 1Wire xAP nodes now report changes of sensor values as xapbsc.event. Previously it was implemented as periodic reporting using xapbsc.info. The xapbsc.query is still available to obtain the current values of any or all sensors.
Old September 4th, 2006, 02:05 PM
UI Change and Temperature Discrete Support
The user interface has been made consitent with xapmcs1wire UI where presence LEDs are added, Reject/Accept selections and reverse polarity for discretes. The Tempeature sensors now also support the newly added Temperature Discrete logic that was added recently to xapmcs1wire. Updates in V1.3.6
Closed Thread
HTML code is On
