Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > MCS Plug-Ins and Scripts > xAP > xAP Library
xAP Library Library area for plug-in nodes. Use the discussion area to discuss these - posting here is only allowed by the moderator.
Old February 20th, 2010, 08:34 PM
Michael McSharry's Avatar
Michael McSharry Michael McSharry is offline
xapmcsMultimeter Telemetry for DMM
xapmcsMultimeter provides an interface to the Radio Shack 220-0812 digital multimeter to provide telemetry of the multimeter readings in the form of LAN messages using xAP protocol. The multimeter provides 26 measurement modes (e.g. AC voltage, DC voltage, ohms, etc.). Each of these, when selected on the meter, is transmitted as the raw reading, the rate of change of the reading, the maximum reading and the minimum reading. The content of these messages can be recorded in a database such as is supported by xapmcsDatabase, or accepted in other automation applications such as Homeseer where event logic can be used to trigger other actions.
xapmcsMultimeter will sense the user selections made on the multimeter and automatically report the measurement being made. It will identify the type of measurement, include measurement units, and scale the value as the meter auto-ranges from nano, micro, kilo, and mega. If a capacitance measurement is being made it will be reported in microFarad units in one device and nanoFarad units in another to ease the data collection capabilty of other applications. Similiar handling is done for amperage and voltage.
xapmcsMultimeter will compute the minimum and maximum readings unless the meter is setup to report only maximum or minimum readings. In this case the maximum and minimum reported by xapmcsMultimeter will be maximum or minimum from the meter. When the multimeter is in this mode xapmcsMultimeter will not report a current reading or a rate of change of the reading.
Version History
1.0.0.1 PR1 Change display date format to use 24 hrs clock if not USA
Available as http://mcsSprinklers.com/xapmcsMultimeter.zip
Old February 21st, 2010, 07:01 AM
Pete's Avatar
Pete Pete is offline
Purchased a Radio Shack 220-0812 digital multimeter last week. Will plug it into the Quatech box today. I know there are variances expected. Do you know what standard min/max values should be?
You just gave me a reason to purchase Lantronix WiBox.
Automator
HS3 Pro & Lite Edition Beta 3.0.0.4449
Old February 21st, 2010, 03:57 PM
I have not researched it. I think I get quite a bit of variation here, but my location is somewhat remote so the quality of service may not be as good as some more urban areas. Just watching it now. Based upon this morning's data there may of been a load demand as the neighborhood wakes up.
I did not try it on Quattech, but should be no issue. My testing was with Lantronix EPS12. The WiFi certainly has come down in price over the past year.
Old February 21st, 2010, 04:08 PM
Pete's Avatar
I guess still a bit paranoid about plugging my DMM into a serial port directly so Quatech for now WLAN in the next few days...I believe I have a Lantronic EPS12 in my retired but not forgotten HW box...could use that too....
Old February 21st, 2010, 05:29 PM
Pete's Avatar
Working well with Quatech server. Now to some graphing.
Not sure if configured correctly. I have the application installed on another server. It is reading the voltages fine. I configured the variables on the HS box using the XAP application. It saw the three voltage variables. I saw them initially on my status. I also configured them as variables to graph. Just noticed that the variables are reading zeros right now. Will check configs.
Somehow unchecked some options on XAP main config page. All is well. Thanks Michael.
HTML code is On
