Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > MCS Plug-Ins and Scripts > xAP > xAP Discussions
xAP Discussions Discussion area for the xAP plug-in and the plug-in nodes posted in the xAP Library.
Old April 1st, 2014, 11:51 AM
marekd1 marekd1 is offline
xAP 3.0.0.38 plugin for HS3
Hello Michael, in your last update you mentioned that the 3.0.0.38 xAP plugin for HS3 3 plugin available in HS3 Updater.
Can you point me to the category where this plugin resides? I was unable to locate it. I do have 3.0.0.37 which was installed manually but do not seem to link it to the upgrade.
Old April 1st, 2014, 03:31 PM
Michael McSharry's Avatar
Michael McSharry Michael McSharry is offline
I guess it is not up on the Updater yet. I submitted all the xAP applications for install from the Updater but there was some confusion. I'm certain Rich will get back to it when he has time.
Old April 1st, 2014, 06:27 PM
Thanks Michael for the update.
Old April 10th, 2014, 03:20 AM
jfla jfla is offline
Hello, Michael
where can i find the last release of mcsxap plugin for hs3?
thanks.
JF
Old April 12th, 2014, 05:57 AM
khriss75 khriss75 is offline
Michael,
I'd like to test your last xAP plugin but for me is impossible to find it (by web and updater).
Can you help me?
Cristian
Old April 12th, 2014, 03:26 PM
I added the link to where the updated picks up the file http://mcsSprinklers.com/mcsXap_3_0_0_38_HS3.zip. You can extract the .exe and put it in the HS3 folder.
Old April 13th, 2014, 08:56 AM
Thank you Sir!!
Regards
Mark
Old April 13th, 2014, 11:59 AM
Thanks, Michael,
JF.
Old April 19th, 2014, 07:18 PM
Does anyone have the NETIOM xAP board running with the xAP? I can read the inputs but cannot set the outputs. Any pointers would be greatly appreciated.
Mark
Old April 19th, 2014, 09:54 PM
Did you see the recent post and update about the Netiom using V=12 which has a different UID format. mcsXap was updated to recognize the older format.
Old April 20th, 2014, 08:40 AM
Thanks Michael. No I did not see that. I guess the only way then would be to write a custom script?
Mark
Old April 20th, 2014, 12:23 PM
No. The last version that was posted will recognize the source message type when it is accepted and then use the correct format for the UID that it is expecting.
Old April 20th, 2014, 12:31 PM
Thanks Again Michael!!! Upgraded to the latest and all is happy again.
HTML code is On
Does this plugin work with the Windows Media Center plugin? rdimitri SqueezeBox Plug-In (3P) 0 May 16th, 2011 05:05 PM
Upgrade procedure for ACRF plugin from W800 free plugin htsource ACRF Processor (3P) 14 January 26th, 2006 11:21 AM
Switch-to messages, plugin restart, and plugin startup Michael McSharry Plug-In Development 4 January 27th, 2003 11:20 PM
GamePort Plugin > Motion Sensor Plugin Jebus Plug-In Development 0 October 29th, 2002 10:41 AM
