Go Back   HomeSeer Message Board > Developer Support > Scripts & Plug-Ins:Development and Libraries > HS3 Scripting
HS3 Scripting Discussions related to the scripting under HS3.
Old January 1st, 2015, 01:37 PM
Gogs's Avatar
Gogs Gogs is offline
Unhappy OK Capi!!! Help
I am trying to create a script in HS3 which would have been a one liner in HS2 and cannot figure out how to do it.
I have a event that fires a script, non working at this point, when the value of a virtual device changes. I would like the script to then trigger a z-wave device to the level of the value in the virtual device.
Sounds like a simple thing to do, but how?
Any help appreciated.
HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
Old January 1st, 2015, 01:46 PM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
HST's recommendation is you should use an event whenever possible. Can you use an event instead?
Sent from my SCH-R970X using Tapatalk
Old January 1st, 2015, 01:57 PM
Gogs's Avatar
Nope, because HS3 does not support simple commands like HS.Exec and so on.
Old January 1st, 2015, 02:03 PM
Rupp's Avatar
Rupp Rupp is offline
Sure you can. Set up the event to turn on the device. Many one liners can be done via the action in HS3. You use "control a device".
-Rupp
Old January 1st, 2015, 02:11 PM
sparkman's Avatar
sparkman sparkman is online now
Hi Gogs,
Here's an example. You pass two parameters to it separated by a comma. The first the device ID of your virtual device, and the second is the device ID of your z-wave device.
Cheers
Al
Sub Main(ByVal Parms as String)
	Dim ParmArray() as String
	ParmArray = Parms.tostring.split(",")
	dim targetDev1 as Integer = CInt(ParmArray(0))		'reference ID of the virtual device to use for value
	dim targetDev2 as Integer = CInt(ParmArray(1))		'reference ID of the device of the z-wave device
	Dim dev1Value As Double
	dev1Value = hs.DeviceValue(targetDev1)
	hs.CAPIControlHandler(hs.CAPIGetSingleControl(targetDev2, false, CStr(dev1Value), false, true))
End Sub
Old January 1st, 2015, 02:27 PM
Gogs's Avatar
Yes appreciate that Rupp, but I cannot, at least I think I cannot tell a device to dim to the value of another virtual device with one liners.
Could be wrong of course.
Old January 1st, 2015, 02:28 PM
Gogs's Avatar
Originally Posted by sparkman View Post
Hi Gogs,
Cheers
Al
End Sub
Al, thanks for that bit of code, I will play with it tomorrow.
Much appreciated.
Old January 1st, 2015, 02:32 PM
sparkman's Avatar
Much appreciated.
You're welcome.
Cheers
Al
Old January 2nd, 2015, 05:00 AM
Cleavitt76 Cleavitt76 is offline
You can use the following one-liner to set the dim level of one device to the value of another. In this example device 72 is being set to the dim level of device 6. However, it will probably only work for dim levels (1 to 98) not "On", "Off", or "On Last Level". That is probably doable as a one liner, but it would be so complex and repetitive that a script would be a much better idea.
PHP Code:
 &hs.CAPIControlHandler(hs.CAPIGetSingleControl(72FalseCStr(hs.DeviceValue(6)), FalseTrue))
This is the same as Sparkman's code, but consolidated into a single line.
Old January 2nd, 2015, 01:11 PM
Gogs's Avatar
Hi Sparkman,
trying your script but receiving this error
Jan-02 16:57:37 Error Running script, script run or compile error in file: C:/Program Files/HomeSeer HS3/scripts/Desk Lamp.txt1006:Expected ')' in line 1 More info: Expected ')'
This is the modifications I made to the script.
dim targetDev1 as Integer = CInt(ParmArray(Q42)) 'reference ID of the virtual device to use for value
dim targetDev2 as Integer = CInt(ParmArray(R1)) 'reference ID of the device of the z-wave device
End Sub
I know I am being stupid, but once I get the first script working I can move on from there.
Old January 2nd, 2015, 01:15 PM
Rupp's Avatar
Gogs,
This is a .net script and as such needs to be saved with a .vb extension rather than a .txt which is for vbscript scripts.
Old January 2nd, 2015, 01:19 PM
Gogs's Avatar
Gogs,
Ahh, thanks Rupp, now that was me being stupid.
Old January 2nd, 2015, 01:27 PM
Gogs's Avatar
OK script running but now getting this error.
Jan-02 17:23:25 Error Compiling script C:\Program Files\HomeSeer HS3\scripts\Desk Lamp.vb: 'R1' is not declared. It may be inaccessible due to its protection level.
Jan-02 17:23:25 Error Compiling script C:\Program Files\HomeSeer HS3\scripts\Desk Lamp.vb: 'Q42' is not declared. It may be inaccessible due to its protection level.
Jan-02 17:23:24 Event Running script in background: C:/Program Files/HomeSeer HS3/scripts/Desk Lamp.vb
I take it the reference ID is not the house/unit code, then where do you find it?
Old January 2nd, 2015, 01:36 PM
sparkman's Avatar
OK script running but now getting this error.I take it the reference ID is not the house/unit code, then where do you find it?
Hi Gordon,
Correct. If you go the device management page and then click on the advanced tab you will see it.
Cheers
Al
PS There are commands that'll work with the house/unit code so if you'd prefer to use those, I can adjust the script.
Old January 2nd, 2015, 01:38 PM
jon00's Avatar
jon00 jon00 is offline
Gogs,
You get the reference from clicking on the respective name link in the device management page.
You can also substitute the code as follows:
dim targetDev1 as Integer = CInt(ParmArray(hs.DeviceExistsAddressFull("Q42", False)))
dim targetDev2 as Integer = CInt(ParmArray(hs.DeviceExistsAddressFull("R1", False)))
Jon
Old January 2nd, 2015, 02:11 PM
Gogs's Avatar
Thanks Guy's for all your help, I think I am getting there; slowly.
Now have an error, which I used to get in the old HS2 days
Jan-02 18:07:20 Error 1 Running script C:\Program Files\HomeSeer HS3\scripts\Desk Lamp.vb :Exception has been thrown by the target of an invocation.Index was outside the bounds of the array.
Jan-02 18:07:20 Event Running script in background: C:/Program Files/HomeSeer HS3/scripts/Desk Lamp.vb Jan-02 18:07:20 Event Event Trigger "Lighting Study Desk Lamp"
Hmmm
Old January 2nd, 2015, 02:13 PM
sparkman's Avatar
Can you post your complete script and a screen shot of the event that you're using to call it?
Cheers
Al
Old January 2nd, 2015, 03:53 PM
Gogs's Avatar
The Script is:[quote}Sub Main(ByVal Parms as String)
dim targetDev1 as Integer = CInt(ParmArray(7)) 'reference ID of the virtual device to use for value
dim targetDev2 as Integer = CInt(ParmArray(6)) 'reference ID of the device of the z-wave device
End Sub[/quote]
Screen shot:
Old January 2nd, 2015, 03:54 PM
Gogs's Avatar
Screen shot did not work, will try again.
Old January 2nd, 2015, 04:03 PM
sparkman's Avatar
Hi Gordon,
Call the script as per my original post:
Also change the script back to using the "0" and the "1". That way it will use the parameters from the event that you are using and you can reuse the same script for multiple events (& devices). The first 4 lines in the script are used to read the parameters passed from the event and should not be modified.
End Sub
CAPI for scripts bdickhaus HS3 Plug-In Development 10 March 4th, 2018 11:38 AM
Capi needed?? Skinnez iTunes DAAP (3P) 10 December 31st, 2014 07:20 PM
CAPI? MrSkippy HS3 Scripting 2 April 4th, 2014 06:54 AM
Help with CAPI please naellis HS3 Scripting 4 March 26th, 2014 09:03 AM
CAPI Example for scripts for dummies like me Jon798 HS3 Plug-In Development 13 November 13th, 2013 08:40 AM
