Go Back   HomeSeer Message Board > Camera Plug-ins > Camera Discussion
Old February 13th, 2017, 02:01 PM
jrfuda's Avatar
jrfuda jrfuda is offline
Universal Camera Web Page
I've been scouring the web looking for some simple code to display a camera on a web page. Many years ago I had something setup; I cannot remember if the whole page refreshed or just the image, however, nothing I can find now seems to work.
What I'd like to be able to do is using any camera as a source, streaming either RTSP or continuously reloading a jpg, create a web page that shows multiple and/or one-at-a-time camera feed. All the scripts I've found seem to not work.
Right now, all of my cameras are hikvision and I use a hikvision NVR to manage them. I can also access each camera's RTSP, JPEG and MJPEG streams individually, and the JPEG/MJPEG are how I currently have them integrated into HSTouch. It's VERY slow, however. The activex that shown them in IE shows everything in real-time in HDTV quality, even when all 16 cameras are on the screen at once. How do we get that kind of performance on a non-activex containing web page.
Ideally, I'd like to be able to just serve the pages off my HS machine, however, I can easily throw an RPi or PINE64 at the problem, if I need to serve pages with them or install a view only (non-recording, since my NVR already does that) camera program that will give me the feed I'm looking for.
Any ideas?
John
Hardware: i5-6400T w/16GB RAM & SSD w/HS3Pro, Z-Net, Harmony Hub x2, Echo Dot x2, Ocelot
Plugins: Z-wave, HSTouch, BLBackup, Harmony, GTS CPUXA, UltraMon3, Nest
HSTouch: Multiple Android Devices; 5 x ToteVision MD-1001 10.1" Win 7 Tablets
Devices: Cooper RF9501 x4, RF9517 x6, RF9534 x1, RF9540-N x7, RF9542 x1, RF9542-Z x2, RFHDSCG x1, RFWC5 x5; Intermatic HA02 x6; FortrezZ MIMOLite x3; Leviton VRPD3-1LW x4, VRR15-1LZ x6; Nest Tstat & 9x Protects; Dragon PD-100 x3, PA-100 x3
Old February 15th, 2017, 07:44 AM
Pete's Avatar
Pete Pete is offline
Here I have had good luck with VLC. I do custom line commands and leave buttons on the left.
You can size the screen / window anyway you want. It is local only.
Automator
Hardware | Haswell Intel iSeries 3 - 16Gb | Pine64 - 2Gb computers | Openpeak Intel Atom SoC tabletop touchscreens (15 HS tabletop tablets)
HS3 Pro & Lite
Edition Beta 3.0.0.435 | HS3 Wintel Touch | Ubuntu 16.04 64 bit | Oracle Windows Virtual Box ==> for Wintel only SAPI and HS3 plugins
HS3 Plugins - a bunch
Light switches - X10,UPB, ZWave and Zigbee
Speech - Microsoft SAPI - Neospeech - Amazon Echo
Security - Leviton HAI Omni Pro 2
Weather - Davis Vantage Vue - MeteoStick
Firewall - PFSense
CCTV - Zoneminder
Audio - Russound - AB8SS
Old February 15th, 2017, 11:27 AM
lj502 lj502 is offline
John, I do this now with my BlueIris server, i was never able to get any kind of performance through HSTouch handling the camera feeds. I have a small htm file for each camera and one for all cameras that allows selection by touch (I found them on a BlurIris forum) They get displayed in a text box inside HSTouch but never go through the HS3 server. I get 10 fps easily with the only catch that HSTouch wont let the connection die unless you clear the address from the text box "before" you leave the page or even kill HSTouch. I can put the files up for you but they are for BlueIris which I highly recommend.
Another much better option if you happen to run Android clients is using TinyCam Pro, with it I can overlay H264 camera feeds on top of what ever is running on the tablet in a sizable movable window. I also fire those from HS3 via the Tasker plugin or with actual individual apps that i made for each camera so they can be run locally on each tablet as well, hands down the best solution you will find.
John
Old February 16th, 2017, 08:17 PM
jrfuda's Avatar
Originally Posted by lj502 View Post
...I do this now with my BlueIris server...
I installed the Blue Iris demo on my old Dual Core HS machine and am testing it with 5 cameras - just for streaming as my NVR takes care of everything else. It's running 90-100%, steady, but it's serving the 5 cameras I'm testing very well. I still have 11 more to setup. At first, it was lagging like crazy until I swtiched it to stream from the mjpeg substream, now I'm getting a sold 10 fps, even with all 5 cameras up at once. Using the web pages here:
https://ipcamtalk.com/threads/i-made...-view-page.93/
I get a fast, clean, scalable interface that looks like it will work perfect in HSTouch.
I'm going to see how many cameras I can add before my old PC can't keep up any longer, but I'll probably need another i5-6400 machine (lenovo m700 tiny is what my current HS machine is) to run Blue Iris effectively. Again, all my recording is on my NVR (16TB), so I won't need much storage on the BI PC.
Old February 17th, 2017, 05:25 PM
Vincenttor Vincenttor is offline
You should look for a cpu that supports or has a gpu on board.
I believe those all have hardware acceleration available.
(Intel® Quick Sync Video)
Turn direct disc recording on instead of the normal setting. - works now also good with your "old" computer !
This will save allot of CPU usage with blueiris
Old February 18th, 2017, 05:09 PM
mulu mulu is offline
John
lj502, can you share what you have in the htm file for both the single cameras and all cams. This is actually exactly what I want to do, i.e. have a camera page in HSTouch with all cameras displayed. Then when clicking on one of the cameras it's being enlarged showing just that camera.
Old February 18th, 2017, 09:05 PM
Here you go, this is for camera 2 obviously, you can set the number in the file by replacing the "Cam2" with your other cameras short name in BlueIris and the rename accordingly, you will also need to change the file extension from txt to htm and put it in your www folder on your Blue Iris server. You will need the above package from the first post, it contains the necessary support files to make it work.
Let me know how it goes
John
Old February 18th, 2017, 11:39 PM
lj502, thanks a lot for that file. This is more complex than I expected. I thought it might just be a one-liner with an img or video link embedded in the website. How do you display all cameras on a single page? Are you just adding each individual one as a separate element on that site?
Old February 19th, 2017, 12:51 PM
Inside that package from first post is a few differant web pages that all serve video from your BlueIris server, one named (allcams.htm) will show all your cameras in a grid with nothing else, you just click a camera image and it goes full touch again and back to the grid view. It is really not difficult, the first post links to the files and you just unzip them on your BLueIris server to the www folder inside the BlueIris program files. Test it out by opening a browser on another device on the same network and entering (http://your local ip of blueiris server with the port#/allcams.htm) (http://192.168.1.xxxort#/allcams.htm) and you should have a stream.
John
Old February 19th, 2017, 12:52 PM
The link is in the fourth post, sorry
John
Old February 21st, 2017, 10:43 AM
jrfuda's Avatar
Interesting, once I purchased a BI license, my CPU use went down and is now (with a client connected) in the 30s with BI minimized and in the 40-60s with it displayed on screen.
Regardless, I found a refurbished HP ProDesk 400 G2 on Woot with an i5-6500T, 8GB RAM and a 128 SSD for a great price and it supports QSV. I like the small form factor and low power usage and it will be a good compliment to my Lenovo Mini that runs HomeSeer. It's amazing how powerful these machines are and still sip electricity!
Again, I have a 16TB dedicated NVR for recording, so all BI is going to do is send my clients an easy to handle feed. I even noticed my Android IPCamViewer works better with the BI feed than it did interfacing directly with the cameras.
Another note: I had issues with allcams.htm displaying in HSTouch - just gave me a black screen for some reason. I ended up commenting out the parts of jpegpull2.htm that I did not need, so now it looks just like allcams.htm in a browser, and it works fine. Is it that allcams uses the activex viewer and jpegpull2 uses java?
Old February 22nd, 2017, 12:05 AM
Ok, I got confused because John's post (#3) was before the post with the link to the files (#4). So post #4 is a follow up for what John was referring to in his post (#3). I now copied the files to the www directory of BlueIris. When I pull up http://localhost:[BlueIrisPort]/allCams.htm I can see all cameras. However, when I set the text property to that same value I just get a blank/black image.
jrfuda, what did you comment out to make this work? I am actually not even sure how jpegpull2.htm is related to allcams.html.
Now this brings up another question. Why is an html file required for showing an individual camera like John does? Looking at the allcams.js file, it seems all of this is already handled in that script, i.e. clicking on a video feed doesn't load a separate page but simply changes the source of the feed to the single camera, hence one always stays on the same HSTouch site. Obviously I am missing something.
Old February 22nd, 2017, 06:40 AM
jrfuda's Avatar
mulu, the attached zip has my modified version of jpegpull2.htm
I just commented out a few lines, and probably did a sloppy job of it as I know squat on coding.
Full credit for this page goes to bp2008 at ipcamtalk, since I'm reposting slightly edited code he created. I think I owe him a PayPal donation!
This (or allcams if it works for you) should be the only file you need to load.
All your cameras will display, click and camera, and that camera will fill the display. Click again and return to the view of all cameras.
If it's not working right in HSTouch, it's becuase your browser it out of date. On my Windows 7 tablets, HSTouch was working fine, but this page was not. Once I upgraded IE from 9 to 11, these pages worked fine. With IE 9 running, the page would display, but clicking on an individual camera image did nothing.
I also have BI set to not prompt for user/pass on LAN, which makes the page come right up. The only bad thing is it treats "LAN" as only the same subnet and I cannot see where to expand this to specific subnets, as when I VPN into my network, my VPN clients are on a different subnet (I have 3 subnets - main, VOIP and VPN).
Anyway, hope you can just drop the attachment into your BI WWW root and it works!
EDIT: I had a few issues with the top bar displaying again when motion was detected. I've deleted the modified jpegpull2 and now attached a file jpegpull3 which fixes this issue and now has the excess code deleted instead of commented out.
Last edited by jrfuda; February 25th, 2017 at 07:03 AM. Reason: changed attachment
Old February 22nd, 2017, 01:31 PM
I think BlueIris disables direct to disk recording and a couple other things on the demo version.
I use the allcams but on some uses I just want a single camera (front door, back gate) displayed with no interaction.
I have been trying other methods on Android to display my cameras, TinyCam Pro is fast and stable but it also has widgets for camera displays that you can set the update interval so you are getting snapshots instead of full video. It also has a Tasker plugin that I can bring up floating windows of camera views on top of any app, I just set a time out in the Tasker task so the feed goes away after 20 seconds, If I want I just tap the camera window and the TinyCam app opens.
I have found that if you want full video on your HSTouch clients showing all the time you will be chasing your tail trying to get it right. The other thing about letting TinyCam handle the video is it pulls your video regardless of local connection or remote connection, which is tough inside HSTouch.
John
Old February 22nd, 2017, 03:44 PM
jrfuda's Avatar
...the only catch that HSTouch wont let the connection die unless you clear the address from the text box "before" you leave the page or even kill HSTouch....John
Just now catching this comment you made earlier.
So, HSTouch continues to stream the BI page, even after you leave the page unless you clear it? Is that on Windows clients or Android?
So far I've not seen any performance hits if this is true for Windows clients, but I only have 1 full time client running at the moment, with the others part-time android or future full timers still on the test bench.
I assume I need to have my "home" button on my camera screen clear the text box, or have my home screen clear the text box upon load (which is probably better since I have "return to home screen after x time setup).
I will eventually need a few screens that only display single cameras, for controlling/monitoring my garage door and two automated gates (for visual confirmation of open/close status, even though they have sensors as well), so I'll need to look into the methods to display a single camera in an HSTouch textbox as well.
Old February 23rd, 2017, 06:53 AM
jrfuda's Avatar
Thumbs up
I received my i5-6500T PC yesterday and got BI moved to it in short order.
Amazing performance. With 5 x LTS (Hikvision OEM) Cameras, pulling the secondary stream's mjpeg feed at 15 fps with a 15 keyframe setting and highest quality (don't need to pull the main stream since BI is only streaming to non-HD clients, and I'm leaving the main stream for my NVR to record) and BI never gets over 9% CPU use, even with 3 clients connected simultaneously. The PC as a whole is running in the low-to-mid teens. It looks like I'll have plenty of overhead for my 16 cameras.
I think the change from the old laptop's 100Mbit ethernet to the Gbit ethernet on the new PC makes a difference as well as the network usage is a steady 25Mbps, which would have been pushing it scaling up to 16 cameras. My entire network is gigabit on Ubiquiti hardware (2 x 48 port unifi switches, one POE and one not, plus an 8 port each in the garage and yard) with 10Gbit copper between 48-port switches and Gbit fiber (isolation due to previous lightning issues) to the 8 port switches, so I will not have any network-related performance issues.
I probably don't need 15fps, but it's working without issue for now, so I'll keep it there until I start seeing performance hits.
I've started playing with the BI plugin too and am pleased so far, monitoring 2 of the cameras for motion and controlling virtual motions in HS with alerts. I think I'll start a thread in the plugin forum with some questions I have about plugin utilization.
Thanks for steering me to BI, should've listened sooner!
Old February 25th, 2017, 07:05 AM
jrfuda's Avatar
I had issues with my modified jpegpull2 showing the menu when motion was detected, so I've tweaked it some more and replaced the earlier file with a new jpegpull3.
Old April 26th, 2017, 07:18 PM
nofreeze nofreeze is offline
Looks complicated. Does anyone have a video tutorial on how to get live camera feeds into HStouch or how to display the live feed within HStouch? I am very new and trying to figure out the best way to show live feeds.
Thanks for the help
Jon00s Web Page Builder - camera page Steve Q Jon00's plugins and scripts 10 September 10th, 2008 03:54 PM
Camera streaming page benseer Jon00's plugins and scripts 40 June 6th, 2008 12:07 PM
Page to Control the Ninja Camera [ASP] johnwpb Script & Plug-In Library 0 November 2nd, 2004 01:06 PM
Veo Web Camera in HomeSeer Home Page - Please help hlkc HomeSeer General Discussion Area 14 April 30th, 2004 12:44 PM
IP Camera in HS Web Page hlkc HomeSeer General Discussion Area 8 April 20th, 2004 07:34 PM
