Go Back   HomeSeer Message Board > Camera Plug-ins > Camera Discussion
Old June 4th, 2017, 04:46 PM
mike2016 mike2016 is offline
Seer Plus
Hikvision motion detection?
Has anyone successfully setup the motion detection in HIKVision cameras?
I have the 8 port HIK NVR and 5 cameras. They support motion detection, but the setup is so confusing. I setup the motion detection area but it doesn't seem to do anything.
and how do you make it trigger an output to HS3?
Old June 6th, 2017, 10:57 AM
Tomgru Tomgru is offline
i do... but i do motion detection through blue iris, so maybe not that helpful.
Old November 9th, 2017, 10:29 AM
Freddan101 Freddan101 is offline
Did you ever get motion detection events to be sent directly from the camera to HS?
Old November 9th, 2017, 04:04 PM
IanIreland's Avatar
IanIreland IanIreland is offline
That's how I do it as well.
Old November 17th, 2017, 11:36 AM
I too use BI to detect motion. I have setup virtual devices in HS that are triggered by BI and it works very well and can be used to turn on lights for example.
But in the name of integrity I'm thinking about disabling the indoor cameras in BI when someone is at home. By doing so I will loose the motion detection functionality. That's why I thought about using the motion detection in the camera itself.
I have the Cube cameras indoors which have separate motion PIR why in theory it could do an even better job than BI to detect motion. Though I can't figure out if it would be possible to send a trigger to HS directly from the camera.
Anybody know?
Old November 17th, 2017, 01:53 PM
IanIreland's Avatar
Can you something with profiles in BI?
HikVision camera plugin for motion alerts - C# example sgieseking HS3 Plug-In Development 44 June 25th, 2018 01:44 PM
Motion detection delay computernerd HomeSeer General Discussion Area 6 October 13th, 2009 11:43 PM
Motion detection from cameras estratos HomeSeer General Discussion Area 6 November 17th, 2005 09:38 AM
Motion detection trigger help steveblackshaw Script & Plug-In Library Discussion 2 February 16th, 2002 09:18 PM
