Insteon plugin hangs up.
    I am using a brand new HS3 Hometroller SEL (Linux) system connected to an Insteon 2413U. The 2413U shows up on the config page, however, I can not add any other devices. If I try adding an Insteon device automatically by using the set button on the device, it will blink and HS will say please wait programming device and then hang. If I try adding it manually by entering the address, the device will show up on the Insteon config page, but no HS device is created. I recently, upgraded to the HS3 Hometroller SEL, however, the Insteon 2413U successfully worked with the prior HS installation.
