Go Back   HomeSeer Message Board > Energy Management Plug-ins > Energy Management Discussion > HomeSeer Current Cost Envi Plug-in
HomeSeer Current Cost Envi Plug-in Discussions related to the Current Cost Envi plug-in which is used with the Current Cost energy monitor.
Old November 8th, 2017, 11:32 PM
rmuziani rmuziani is offline
Seer Deluxe
Working with HS3?
I been reading the posts in this forum and can't figure if this plug in is work with HS3. I been using it with HS2 and it's been great. But can't get it working with HS3. I can get it connect to the com port, but can't get any info into the devices.
Any help would be appreciated.
Ty
Old February 10th, 2018, 09:02 PM
scubajamie scubajamie is offline
Seer
Sorry for the late reply. This plugin seems to have been completely forgotten but they don't forget to charge you for it.
Short answer, yes.
Long answer... I'm running HomeSeer 3.0.0.368 on a HomeTroller Zee S2 upgraded to a Raspberry Pi 3. With some tinkering I have the beta version of the plugin 3.0.0.35 working.
The main issue I have once I got it working is on HS Touch iOS app, my thermostat room temperature thermometer reading is pulled from the CurrentCost unit in my cold basement, not the thermostat itself.
Some issues I had setting up were setting the baud rate every time the unit restarts (won't save in config) and also talking to the USB port in general. Installing the current version (3.0.0.33) before installing the beta seems to have fixed that problem.
I am at a complete noob experience level, but I managed to push the right buttons and yell at it enough to at least get it pulling data for the CurrentCost Envir unit.
Good Luck!
UPDATE: Deleting my thermostats temperature child and rescanning the node fixed my thermometer issue. Also, the baud rate seems to have stayed since my last restart. Maybe because I also edited the rate chart? With those issues fixed, it seems to be working 100% at this time.
HTML code is Off
Event working but Alexa says its not working charlesmbell HomeSeer Amazon Echo Skill 0 April 23rd, 2017 09:29 AM
EVENT:"Control a Device" Not working, "Send X10" Working cyber_jocky HS3 / HS3PRO Discussion 6 May 1st, 2016 06:05 PM
All working -> switch resets -> nothing working tahl Insteon Plug-in (Mark Sandler) 11 March 9th, 2013 06:42 PM
weather not working.. tips to get it working? purezerg Jon00's plugins and scripts 6 January 26th, 2009 02:26 PM
One LM12 not working through events, while working directly rc-man HomeSeer General Discussion Area 6 February 2nd, 2005 02:32 PM
