I may be missing something obvious, but how do I change the name of a room or floor in homeseer? I found the setting to change the labels "room" and "floor" but as far as the names in each category it seems I can only add to the list.
How do I change the names of rooms/floors?
Are you referring to "Location 1" and "Location 2" as modifiers to the device list? You can only explicitly add to the list, but the list consists only of designations that you have actually assigned to a device. If you change the designation of all devices so none of them has 'basement' as a designation, for example, then 'basement' will disappear from the list.Mike____________________________________________________________ __________________
Thanks.
As a follow up question, where is stuff like this stored? Does homeseer work off a SQL database? Is it in xml files somewhere? I'd love to be able to access the configuration data directly and be able to do mass changes with sql or a text editor instead of clicking through the web interface.
