I'm not sure if this is a problem with the hardware or my setup, but I'm hoping you can help me troubleshoot and get it working.
HS3 Pro Edition 3.0.0.152 (Windows)
Plug in 3.0.5528.32889
Global Cache GC-100-12/18
Firmware 3.2-12
All 6 IR ports are set to IR Out
I'm able to log into the GC-100 and run tests
When I select an IR command to send, I see the network activity light flash, the correct IR port light light up, and the blinking IR emitter flash.
I downloaded the IR codes from the global cache ir database.
I've tried other codes found online, but none seem to do anything.
I got the GC-100 from ebay and the IR emitters from amazon. (http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1)
The devices I'm trying to control at the moment are a Panasonic TV, Panasonic Soundbar, and a custom HTPC running W7 WMC.
I'm coming from Logitech harmony products and they currently work.
Anything you can think of for me to try?
Firmware 3.2-12
