I set an event for "at x time set to y temp." I set it to heat, with a high of 70. i didnt do anything re "low" The event did not trigger. What did I do wrong
event priogramming help
so in your logs you don't see this kind of line at 5:35 AM:
Code:Event Trigger "HVAC HEAT 535 AM 1st floor 70"
if so your problem is related to the event engine, not to the Ecobee plugin.
Not sure what could be causing this. Make sure you did not disable the event by mistake, try another hour to see if that change anything...
