Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old January 18th, 2017, 11:54 AM
mnsandler's Avatar
Insteon Overlord
New Insteon Motion Sensor II...beta support available in the Updater
All,
I have not added support for these as smarthome hasn't provided developer notes yet. I will update this thread once I receive the notes and add support.
Update: Jump to Post #14 to see the latest
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old February 23rd, 2017, 03:39 AM
steveng steveng is offline
Seer Plus
Mine shipped out today
Quick Start Guide and Owner's Manual are out so maybe developer notes as well.
Thanks for all the awesome work.
Steven Giles
Old February 23rd, 2017, 09:56 AM
mnsandler's Avatar
Insteon Overlord
I'll post an update here when I receive the dev notes and start adding support to the plugin.
Old March 22nd, 2017, 02:40 AM
codemonkey's Avatar
codemonkey codemonkey is online now
I've been hitting up everyone I can find to get these docs. Need them for a product that I am have in development. The best I've been able to find out is that Universal Devices Inc. (ISY) was just given the 2844-222 dev docs so that they can start work on adding the device.
Tony
HomeSeer Version: HS3 Pro Edition
Operating System: Microsoft Windows 10 Pro
Processor Type and Speed: i7 - 3.26 GHz
Total Physical Memory: 16Gig
Plugins: BlBackup | EasyTrigger | FitbitSeer | HSTouchServer | Insteon | WeatherXML
Old March 22nd, 2017, 07:43 AM
mnsandler's Avatar
Insteon Overlord
Tony
well that's good news. maybe it will show up in my inbox soon.
Old March 30th, 2017, 10:32 PM
tim.palmer tim.palmer is offline
Hey Mark, any news on this yet? I also just received a shipment of these things, just curious if you've been able to test them yet or if you have a beta. Thanks as always!
Old March 31st, 2017, 08:41 AM
mnsandler's Avatar
Insteon Overlord
I have physically tested several, but I can't add plugin support without the developer notes
You can manually link and setup via the user guide, but the plugin will see it as an unregistered device
Old March 31st, 2017, 02:09 PM
mnsandler's Avatar
Insteon Overlord
I got some preliminary docs related to the MS II so I can start adding basic support for the device (support similar to the existing MS). I will try to get this working I the next few weeks.
There are a lot of features packed into this unit so it will take some time to get the rest of them implemented.
I'll update this thread when I post a beta for you to try.
Old April 5th, 2017, 01:47 PM
mnsandler's Avatar
Insteon Overlord
A quick preview of what i have so far.
Four big changes with this unit:
1. you can set the frequency when the unit sends a heartbeat
2. it has a temperature sensor built in (not sure how accurate it is)
3. a tamper switch that activates if the battery cover is removed
4. the unit can be powered by a 3V battery or a usb cable
the heartbeat sends the battery level, and temperature. the battery level is a category (full, good, low, almost dead)
the temperature is reported in degs F. i'll have to see about creating a setting to change this to degs C.
Old April 5th, 2017, 02:19 PM
codemonkey's Avatar
OMG The temp sensor is awesome!!!
Thanks Mark, I am really looking forward to getting mine working. Can test if you need it as I have a few in boxes waiting.
Old April 5th, 2017, 05:36 PM
Seer Plus
I can test as well I have 3 ready to go using USB power.
Thanks Steven G
Old April 6th, 2017, 09:48 AM
Richcorp12 Richcorp12 is offline
Viewer
Happy to test here too
I have 7 of them wiring to be setup. Happy to test any betas for you.
Old April 6th, 2017, 08:13 PM
randy_h randy_h is online now
Cool stuff. Looking forward to it.
HS3 Pro Edition 3.0.0.368
Hardware: Insteon HUB2-V04-20140904 | Ocelot | Secu-16 | Dahua & Noname Cameras |
Plugins: Insteon 3.0.6.16 (mnsandler) | GTS CPUXA 3.5.16105.96 (bbowser) | Blue-Iris 3.0.22.33946 (beerygaz)
Platform: Dell Inspiron 3847, Windows 10, i7-3.6GHz, 16GB memory
Old April 8th, 2017, 10:20 PM
mnsandler's Avatar
Insteon Overlord
All,
I have posted 3.0.6.12 in the Beta section of the Updater which includes beta support for the new Insteon motion sensor II. Please post feedback on the MS II to this thread. remember to backup your Insteon.ini and Homeseer database
if using a battery, remember to put the MS into linking mode before attempting to add it to the plugin. If using a usb, just connect it and add it like any other device. if you switch power sources for some reason, you will need to re-read the settings so the plugin becomes aware of the change. I would suggest doing a Factory Reset on the device before adding it to the plugin.
a few notes about the MS II:
1. stick with Occupancy Mode for now. i need to document the other modes. I'm not even sure of all of them yet.
2. you can set the heartbeat frequency which will also read the battery level, temperature, and light level. the heartbeat will not update any other devices.
3. the temperature reading will be different depending on the power source: usb vs battery. The 'temperature calibration' adjusts the temperature reading by a fraction of a degree (not a whole degree) ; so just add or subtract a few units until you get a reading that matches your standard. there is an option to display the temperature in Celsius. If you change scales, you will need to wait until the next heartbeat for the plugin to convert the temperature. I have not included the temperature scale in the device definition; i plan to do this.
4. when the MS is powered by the usb, you can program it without using the set btn. When the MS is powered by a battery, you need to use the set btn to program links. Other Settings will be programmed on the next received On msg (similar to the current MS)
5. I have not been able to get the Low Battery Warning to trigger nor the Dawn/Dusk device. i have a variable DC power supply that i use to simulate a battery source. Obviously the low battery warning isn't an issue when using a usb; just hide the two battery devices. there is no actual battery voltage reading now just one of four categories: full, good, low, replace (i'm open to different wording).
6. the light level is just for interest at this point.
When you find an issue, please reply here with a sequence of steps I can follow to replicate the issue. A detailed log snippet would be helpful as well.
Old April 9th, 2017, 02:45 AM
codemonkey's Avatar
I'll have some testing results for you starting tomorrow. Thank you!
Old April 9th, 2017, 09:54 AM
Read Settings after On cms - missing?
On the MS-II config page, I do not see this line:
Read settings after On cmds (0=Disable)____
Should there be one for this new device?
I made some settings changes and am having difficulty getting past this advisory notice:
There are Setting and Op Flag changes pending.
Log
Apr-09 6:48:43 AM Insteon Edit Insteon Device #18 Addr: 41.61.63, Name:MS, Location:Hall
Apr-09 6:41:07 AM Insteon Setting status and value for device 41.61.63:1. Old status:100 Old Value:100, New Status:3 New Value:0
Apr-09 6:41:07 AM Insteon ProcessGroupBroadcast: Device Hall MS (41.61.63) is group broadcast source (tgt group/button:1) sending cmd 13
Apr-09 6:41:07 AM Insteon Received Hall MS Occupancy Sensor: (41.61.63) Go OFF
Apr-09 6:40:44 AM Insteon Edit Insteon Device #18 Addr: 41.61.63, Name:MS, Location:Hall
Apr-09 6:39:48 AM Insteon Received a Direct ACK from Hall MS (41.61.63): 41 61 63 45 50 C8 2F 20 03
Apr-09 6:39:48 AM Insteon Motion Sensor 41.61.63 Op Flags programmed successfully.
Apr-09 6:39:46 AM Insteon Setting status and value for device 41.61.63:1. Old status:100 Old Value:100, New Status:2 New Value:100
Apr-09 6:39:46 AM Insteon ProcessGroupBroadcast: Device Hall MS (41.61.63) is group broadcast source (tgt group/button:1) sending cmd 11
Apr-09 6:39:46 AM Insteon Received Hall MS Occupancy Sensor: (41.61.63) Go ON
Apr-09 6:39:45 AM Insteon Setting status and value for device 41.61.63:1. Old status:0 Old Value:0, New Status:2 New Value:100
Apr-09 6:39:45 AM Insteon ProcessGroupBroadcast: Device Hall MS (41.61.63) is group broadcast source (tgt group/button:1) sending cmd 11
Apr-09 6:39:45 AM Insteon Received Hall MS Occupancy Sensor: (41.61.63) Go ON
Apr-09 6:39:27 AM Insteon Edit Insteon Device #18 Addr: 41.61.63, Name:MS, Location:Hall
Apr-09 6:39:00 AM Insteon Edit Insteon Device #18 Addr: 41.61.63, Name:MS, Location:Hall
Apr-09 6:37:17 AM Insteon Edit Insteon Device #18 Addr: 41.61.63, Name:MS, Location:Hall
Apr-09 6:29:56 AM Insteon Edit Insteon Device #18 Addr: 41.61.63, Name:MS, Location:Hall
Apr-09 6:25:17 AM Insteon Setting status and value for device 41.61.63:1. Old status:100 Old Value:100, New Status:3 New Value:0
Apr-09 6:25:17 AM Insteon ProcessGroupBroadcast: Device Hall MS (41.61.63) is group broadcast source (tgt group/button:1) sending cmd 13
Apr-09 6:25:17 AM Insteon Received Hall MS Occupancy Sensor: (41.61.63) Go OFF
Apr-09 6:21:22 AM Insteon Edit Insteon Device #18 Addr: 41.61.63, Name:MS, Location:Hall
Apr-09 6:21:06 AM Insteon Edit Insteon Device #18 Addr: 41.61.63, Name:MS, Location:Hall
Apr-09 6:20:46 AM Insteon Edit Insteon Device #18 Addr: 41.61.63, Name:MS, Location:Hall
Apr-09 6:20:36 AM Insteon Received a Broadcast message from Hall MS (41.61.63): 01 41 61 63 10 16 46 8F 02 00
EDIT: I must have hit a default On cmd count, Settings updated and advisory notice went away.
thanks,
randy
Old April 9th, 2017, 11:37 AM
mnsandler's Avatar
Insteon Overlord
Randy,
this is no longer necessary as the settings/readings are read during the heartbeat.
Old April 9th, 2017, 01:59 PM
I consider this a low priority cosmetic issue"
Channel numbers for new features in Edit Device page are not reported exactly as they are on Device Management view.
Old April 9th, 2017, 02:22 PM
codemonkey's Avatar
I added one MS-II normally and had no issues at all.
I tried another with the device replacement option and while it did successfully replace the old motion, it did not add the new devices. Also there are some errors in the log:
Apr-09 11:16:11 AM Insteon ** To request help with this problem please post this log file to the forum along with a detailed description of what lead to this problem.
Apr-09 11:16:11 AM Insteon ** An error occurred in this plug-in. The details have been written to the log file - C:\Program Files (x86)\HomeSeer HS3\Config\Insteon Error Report.Log
Apr-09 11:16:11 AM Insteon ***:Error in ProcessRawReceive: Object reference not set to an instance of an object. -- Details System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_Insteon.hspiAPI.HSAPI.GetDeviceAddress(Int32 ref) at Insteon.Support.Core.InsteonModule.SetHSDeviceValue(Int32 ref, Int32 Val, Boolean TriggerEvents) at Insteon.Support.Devices.MotionSensorIIClass.ProcessGroupBroa dcast(TransmitMsgType Msg, Boolean RemoteMsg) at Insteon.Support.Core.InsteonModule.ProcessRawReceive(Object iCmdStr)
Apr-09 11:16:02 AM Insteon Received Master Bedroom Motion Occupancy Sensor: (41.5F.46) Go ON
Apr-09 11:15:20 AM Insteon Received Master Bedroom Motion Occupancy Sensor: (41.5F.46) Go OFF
Apr-09 11:15:00 AM FitbitSeer Timer elapsed. Updating Fitbit-data.
Apr-09 11:13:43 AM Insteon Received Motion Occupancy Sensor: (41.5F.46) Go OFF
Apr-09 11:13:40 AM Insteon Motion Sensor 41.5F.46 settings programmed successfully.
Apr-09 11:13:34 AM Insteon Received Motion Occupancy Sensor: (41.5F.46) Go ON
Apr-09 11:12:04 AM Insteon Replace device routine complete.
Apr-09 11:12:04 AM Insteon Your system has been reprogrammed to support the replacement device. You will need to power down the device and restart it for some of the settings to take effect (Do NOT factory reset).
Apr-09 11:12:04 AM Insteon Program And Replace Device - Process complete.
Apr-09 11:11:59 AM Insteon ** To request help with this problem please post this log file to the forum along with a detailed description of what lead to this problem.
Apr-09 11:11:59 AM Insteon ** An error occurred in this plug-in. The details have been written to the log file - C:\Program Files (x86)\HomeSeer HS3\Config\Insteon Error Report.Log
Apr-09 11:11:59 AM Insteon ***:Error in CreateDevices: Device 18: Object reference not set to an instance of an object. -- Details System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_Insteon.hspiAPI.HSAPI.CreateDevices(Boolean ReloadTables)
Apr-09 11:11:46 AM Insteon Step 5 of 5: Updating Interface...
Apr-09 11:11:46 AM Insteon Step 4 of 5: Finished updating linked devices, updating groups...
Apr-09 11:11:46 AM Insteon Step 3 of 5: Updating linked devices...
Apr-09 11:11:32 AM Insteon Step 1 of 5: Programming new device with links...
Apr-09 11:11:32 AM Insteon Program And Replace Device - Process starting... (3F.CC.E9->41.5F.46)...
Apr-09 11:11:30 AM Insteon Pass 2, Now attempting to reprogram your system for the replacement device...
Apr-09 11:11:30 AM Insteon Pass 1, updating devices that appear to have stale link tables...RF devices are ignored..
Old April 9th, 2017, 02:38 PM
codemonkey's Avatar
Attempted re-program to no avail. Only way to recover was to factory reset the MS-II and then delete it from your plugin. Then once gone re-add it with a slightly different name. Then it came in correctly.
I was intentionally pushing it with your first beta so was not surprised that it choked a bit.
Tony
HTML code is On
Programming Insteon Motion Sensor JimSpy Insteon Plug-in (Mark Sandler) 1 September 19th, 2016 09:20 PM
Insteon Motion Sensor BIGMACK48 RFXCOM Plug-In (3P) 1 April 23rd, 2010 07:11 AM
Insteon motion sensor compatibility? jdls HomeSeer General Discussion Area 2 November 2nd, 2009 12:08 PM
INSTEON Motion Sensor support? vansluis Insteon Plug-in (Mark Sandler) 56 July 20th, 2009 06:07 PM
Insteon Motion Sensor jamesx0 ISY Plug-in Beta (3P) 5 November 12th, 2008 04:10 PM
