Looking for some clarification on how to use the updater_override.txt. Perhaps I am missing the obvious.
How to use Updater Override?
Originally posted by Bugman1400 View PostLooking for some clarification on how to use the updater_override.txt. Perhaps I am missing the obvious.
Since this plug-in is now in the updater (under Analog and Digital Input/Output Device), you shouldn’t need updater_override.txt.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
What Randy said but if this is for the Arduino plugin there is no zip files as they are all downloaded, so just put the updater override in the HS root and click update listings in the updater to get the update.
Greig.
Sent from my SM-G950F using TapatalkZwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Originally posted by enigmatheatre View PostWhat Randy said but if this is for the Arduino plugin there is no zip files as they are all downloaded, so just put the updater override in the HS root and click update listings in the updater to get the update.
Greig.
Sent from my SM-G950F using TapatalkHS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
