So, i have a virtual switch i'm trying to use to tie a mimolite (that i use to control my garage doors) with a tilt sensor from ecolink that shows door status. I have an event that i want to run that will check the status of the ecolink tilt sensor and then set the virtual switch to the same value if they don't match. however, when i run something like this:
hs.SetDeviceValueByRef(259, 255, False)
Imperihome doesn't see that the value has changed and update the UI to reflect it. If i run it with True instead of False, it works fine.
Any ideas??
Any ideas??
