I have HS vers 2.5 using a HomeSeer Z-Troller Serial interface
I purchased a GoContral model GC-TBZ48 hooked it up using the standard 4-wires and built in batteries. I am able to manually control it at the thermostat and added it to the Z-Troller but when downloading the nodes from the interface I get this error
"Found node 50. Retrieving class and manufacturer information from the node.
Failed to get basic node information from new node 50, cannot continue to load this node."
So I don't see a new device 50 in the list.
I've tried removing and adding it several times but get same error msg every time.
Any suggestions appreciated it's really hot out!
Mike
Mike
