Can anyone confirm if HSTouch energy data and graphs is working in these latest builds?
I tried an earlier build and the HSTouch energy interface was not working.
jul-06 17:13:48 Jon00_FWatcher Client 1 File1 - Now watching file: Header.png jul-06 17:13:39 Jon00_FWatcher Reconnected to Homeseer jul-06 17:13:38 Jon00_FWatcher Client 1 File1 - Now watching file: Header.png jul-06 17:13:29 Jon00_FWatcher Reconnected to Homeseer jul-06 17:13:28 Jon00_FWatcher Client 1 File1 - Now watching file: Header.png jul-06 17:13:26 Jon00_FWatcher Ready jul-06 17:13:26 Jon00_FWatcher Version 1.0.2 jul-06 17:13:26 Jon00_FWatcher Client 1 connected to Homeseer jul-06 17:13:26 Jon00_DBChart Ready jul-06 17:13:26 Jon00_DBChart Version 1.1.1 jul-06 17:13:26 Jon00_DBChart Connected to Homeseer jul-06 17:13:26 Startup Jon00's FileWatcher started jul-06 17:13:26 Startup Jon00's Charting started jul-06 17:13:26 Startup Maximum Uptime Started jul-06 17:13:26 Jon00_PerfMon Waiting to reference on 5 minute duration jul-06 17:13:26 Jon00_PerfMon Ready jul-06 17:13:26 Jon00_PerfMon Version: 1.0.1 jul-06 17:13:26 Jon00_PerfMon Connected jul-06 17:13:26 Jon00_PerfMon Starting plugin... jul-06 17:13:26 Startup EnergyLogging Registered jul-06 17:13:26 Startup Performance monitor has started jul-06 17:13:13 PictureRandom New list has been created jul-06 17:12:57 MaximumUptime Waiting for initialization to run jul-06 17:12:57 MaximumUptime Waiting for initialization to run jul-06 17:12:57 MaximumUptime Waiting for initialization to run jul-06 17:12:56 MaximumUptime Waiting for initialization to run jul-06 17:12:56 Warning Not running script since its already running: C:\HS3\scripts\Jon00RCCNMHS3_A.vben Single instance option enabled in event properties jul-06 17:12:56 Warning Not running script since its already running: C:\HS3\scripts\Jon00RCCNMHS3_A.vben Single instance option enabled in event properties jul-06 17:12:56 Warning Not running script since its already running: C:/HS3/scripts/Jon00RCCNM_MonitorHS3.vben Single instance option enabled in event properties jul-06 17:12:56 Warning Not running script since its already running: C:\HS3\scripts\Jon00RCCNMHS3_A.vben Single instance option enabled in event properties jul-06 17:12:56 MaximumUptime Waiting for initialization to run jul-06 17:12:56 Warning Not running script since its already running: C:/HS3/scripts/Jon00RCCNM_MonitorHS3.vben Single instance option enabled in event properties jul-06 17:12:56 MaximumUptime Waiting for initialization to run jul-06 17:12:55 Info System connected to MyHS Service successfully. jul-06 17:12:55 Info System connected to MyHS Service, waiting for acknowledge... jul-06 17:12:55 Startup Start up complete. jul-06 17:12:55 Startup Starting the HS3 Sentry EXE jul-06 17:12:55 Startup Starting HSSentry watchdog. jul-06 17:12:55 Startup (Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect... jul-06 17:12:55 Startup (Startup.vb script) Scripting is OK and is now running Startup.vb jul-06 17:12:55 Startup Starting Event Scheduler... jul-06 17:12:54 Startup Running the startup script Startup.vb jul-06 17:12:54 System Synchronizing events from 6-7-2017 11:12:54 until now jul-06 17:12:24 HSTouch Server Server started on port 10200 jul-06 17:12:24 Startup Powerfail Recovery will take place in 30 Seconds jul-06 17:12:24 Startup Starting Find service... jul-06 17:12:24 Startup Updater services starting... ====================================== 11 minutes wait????========================== jul-06 17:01:24 Database Opening (Mode=Read/Write) up HomeSeer Energy database C:\HS3\Data\Energy\Energy.hsd jul-06 17:01:24 Speech Listening for remote speaker connections on port 10401 jul-06 17:01:24 Startup Initializing Speaker Client Interface jul-06 17:01:24 Startup Start automation engine... jul-06 17:01:24 Startup Creating ASP.NET application host... jul-06 17:01:24 Web Server Web Server started on port 80 jul-06 17:01:24 Web Server Local IP address (subnet) is: 192.168.***.*** (255.255.255.0) jul-06 17:01:24 Startup HStouch server started, waiting for clients to connect. jul-06 17:01:24 Error Initializing plug-ins Phase 3 Exception: De objectverwijzing is niet op een exemplaar van een object ingesteld. jul-06 17:01:24 Startup Initializing Plug-Ins jul-06 17:01:24 Plug-In Found plug-in: Z-Wave, version: 3.0.1.128 jul-06 17:01:24 Plug-In Found plug-in: weatherXML, version: 3.0.0.63 jul-06 17:01:24 Plug-In Found plug-in: SqueezeBox, version: 3.1.4.12 jul-06 17:01:24 Plug-In Found plug-in: Sonos, version: 3.1.0.20 jul-06 17:01:24 Plug-In Found plug-in: RFXCOM, version: 30.0.0.35 jul-06 17:01:23 Plug-In Found plug-in: Restart, version: 1.0.0.5 jul-06 17:01:23 Plug-In Found plug-in: Pushover 3P, version: 0.0.0.31 jul-06 17:01:23 Plug-In Found plug-in: PHLocation, version: 3.0.1.90 jul-06 17:01:23 Plug-In Found plug-in: JowiHue, version: 1.1.2.9 jul-06 17:01:23 Plug-In Found plug-in: HSBuddy, version: 3.4.316.2 jul-06 17:01:23 Plug-In Found plug-in: Buienradar, version: 3.0.0.21 jul-06 17:01:23 Plug-In Found plug-in: BLGData, version: 2.0.32.0 jul-06 17:01:23 Plug-In Found plug-in: BLGarbage, version: 2.0.5.0 jul-06 17:01:23 Plug-In Found plug-in: BLBackup, version: 2.0.47.0 jul-06 17:01:23 Plug-In Found plug-in: BC4, version: 3.0.0.3 jul-06 17:01:23 Startup Checking for available plug-ins jul-06 17:01:23 Info Remote plug-in API interface started on port 10400 jul-06 17:01:23 Startup This version of HomeSeer is registered as a HS3PRO version. jul-06 17:01:23 Startup Creating Speaker Client Interface Object... jul-06 17:01:23 Startup HomeSeer version is: 3.0.0.337 jul-06 17:01:23 Load Config Loading TIMERS... jul-06 17:01:23 Load Config Loading COUNTERS... jul-06 17:01:23 Load Config 281 total events loaded. jul-06 17:01:23 Load Config Loading Events... jul-06 17:01:23 Load Config Loading Event Groups... jul-06 17:01:23 Load Config 608 total devices loaded. jul-06 17:01:23 Database Loading Devices... jul-06 17:01:23 Database Opening (Mode=Read Only) up HomeSeer database C:\HS3\Data\HetKarnhuis.hsd jul-06 17:01:23 Startup Loading configuration file ... jul-06 17:01:23 Startup Database SAVE process started. jul-06 17:01:22 Startup Local voice recognition class started. jul-06 17:01:22 Startup HSPhone external interface class started. jul-06 17:01:22 Startup Plug-In Interface class started. jul-06 17:01:22 Startup E-Mail RECEIVE class started. jul-06 17:01:22 Startup E-Mail SEND class started. jul-06 17:01:22 Startup Web server class started. jul-06 17:01:22 Startup Application interface class started. jul-06 17:01:22 Startup COM port classes started. jul-06 17:01:22 Startup Creating Class Objects... jul-06 17:01:22 Startup jul-06 17:01:22 Startup ******************************************************************************** jul-06 17:01:22 Startup HomeSeer version 3.0.0.337 Edition: HS3 Pro Starting Now jul-06 17:01:22 Startup ********************************************************************************
jul-06 17:28:40 Error Initializing plug-ins Phase 3 Exception: De objectverwijzing is niet op een exemplaar van een object ingesteld. jul-06 17:28:25 Error Initializing plug-ins Phase 3 Exception: De objectverwijzing is niet op een exemplaar van een object ingesteld. jul-06 17:28:20 Error Initializing plug-ins Phase 3 Exception: De objectverwijzing is niet op een exemplaar van een object ingesteld.
jul-06 18:51:17 Error DeSerializing object (byte): Kan assembly HSPI_HSTOUCH, Version=3.0.0.68, Culture=neutral, PublicKeyToken=null niet vinden. Source=mscorlib jul-06 18:51:17 Error DeSerializing object (byte): Kan assembly HSPI_HSTOUCH, Version=3.0.0.68, Culture=neutral, PublicKeyToken=null niet vinden. Source=mscorlib jul-06 18:51:11 Error DeSerializing object (byte): Kan assembly HSPI_HSTOUCH, Version=3.0.0.68, Culture=neutral, PublicKeyToken=null niet vinden. Source=mscorlib jul-06 18:51:11 Error DeSerializing object (byte): Kan assembly HSPI_HSTOUCH, Version=3.0.0.68, Culture=neutral, PublicKeyToken=null niet vinden. Source=mscorlib jul-06 18:51:04 Error DeSerializing object (byte): Kan assembly HSPI_HSTOUCH, Version=3.0.0.68, Culture=neutral, PublicKeyToken=null niet vinden. Source=mscorlib jul-06 18:51:04 Error DeSerializing object (byte): Kan assembly HSPI_HSTOUCH, Version=3.0.0.68, Culture=neutral, PublicKeyToken=null niet vinden. Source=mscorlib jul-06 18:50:50 Error DeSerializing object (byte): Kan assembly HSPI_HSTOUCH, Version=3.0.0.68, Culture=neutral, PublicKeyToken=null niet vinden. Source=mscorlib jul-06 18:50:50 Error DeSerializing object (byte): Kan assembly HSPI_HSTOUCH, Version=3.0.0.68, Culture=neutral, PublicKeyToken=null niet vinden. Source=mscorlib
