@Randy,
Testing plugin with an RPi OWFS server. HS3 Pro and HS3 ZeeLite running.
Testing with HS3 ZeeLite.
Looking to do maybe 3 separate OWFS servers
1 - Test box currently is running Digitemp and OWFS server.
2 - Wheezy build. Updated Mono. Running Z-Wave via sertonet
3 - doing a 9097 ==> OWFS = temperature, humidity and lightning counter
I am writing a text file for the Digitemp stuff and using a script on HS3 box to read text to variables every 5 minutes.
Is there a way to get your plugin to see the OWFS server variables.
IE: trying to switch port 2121 to 80 to see if your plugin sees server.
[ATTACH]62284[/ATTACH]
I understand the the plugin is written for the EDS embedded OWFS server.
[ATTACH]62285[/ATTACH]
[ATTACH]62286[/ATTACH]
Should I quit trying to do this? It is working fine using Domoticz right now. Not done yet as the RPi is in the attic and have to finish moving two of the sensors to 2nd floor rooms. (IE: attic, lightning sensors in the attic, master bathroom sensors, hallway and need to move study and master bedroom yet)
[ATTACH]62288[/ATTACH]
