I have the plugin installed and it reports "OK" status but does not successfully control the pumps and throws the following errors into the log every 2 seconds as it polls status even though the polling interval is set to 5 minutes. I have attached a screenshot of the log as well. I have Jandy controller with software 1.6.9 on the Autelis.
Thanks for your help.
Oct-18 4:35:15 AM Autelis ERROR System.InvalidOperationException: There is an error in XML document (1, 1). ---> System.Xml.XmlException: Data at the root level is invalid. Line 1, position 1. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.Throw(String res, String arg) at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace() at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlTextReader.Read() at System.Xml.XmlReader.MoveToContent() at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializati onReaderJandyPumpsResponse.Read4_response() --- End of inner exception stack trace --- at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events) at System.Xml.Serialization.XmlSerializer.Deserialize(TextReade r textReader) at HSPI_Autelis.JandyController.GetPumpsCmd() at HSPI_Autelis.AutelisApp.OnPollTimerEvent(Object sender, ElapsedEventArgs e)
Oct-18 4:35:15 AM Autelis DEBUG 404: File not found
Oct-18 4:35:15 AM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not Found.
Oct-18 4:35:15 AM Autelis INFO CMD SENT: http://192.168.0.134:80/pumps.xml?
Oct-18 4:35:15 AM Autelis DEBUG 8 6520 10000000 0 554 0 1.6.9 1508326574 0 0 0 0 0 0 0 0 0 0 0 0 83 60 104 63 0 65 0 F
Oct-18 4:35:15 AM Autelis INFO CMD SENT: http://192.168.0.134:80/status.xml?
