The HAI Plugin is ready for some preliminary beta testing.
Minimum required HS3 version is: 3.0.0.48
The plugin is currently located in the beta section of the HS Updater.
Uninstalling the plugin:
**Disclaimer: I have a virgin panel with only a few test devices attached.
As I continue to install devices, I will add support. It will be somewhat
difficult to cover every individual's panel configuration. For this reason,
I might need to request access to your panel or have you email me detailed
configuration information from the plugin.
A special thanks to Pete for helping get to this point - many thanks!!!
- Disable the plugin from the Manage Plugins page.
- Manually delete the Root Device of the plugin from the Device List page.
- Run the Uninstall_HSPI_HAI.exe from the HS3 root folder.
