I just installed the HS3 version trying to get this one to work better than Homeseers plugin.
As an FYI, this is my first attempt at using a global cache product.
I tried following the help but it is for the HS2 version.
What I have done so far:
Enabled the plugin, went to options and added the IP address of the Global Itach IP2IR device I have. I didn't do this at first because I thought this plugin automatically discovered the device.
Then the plugin wanted me to restart Homeseer which I did. I try to go to any of the tabs and I do not see the device listed. All dropdowns are blank.
I have iHelp running and it shows the device on my network.
Am I doing something obviously incorrect? Do I need to add IR commands to the device before the plugin discovers it? I have not added any IR commands as of yet.
