Error after upgrade
    Error after upgrade
    Getting the following error after upgrading to the latest version (3.0.0.82) of the plugin, and it won't start. Running HS3 Pro Edition 3.0.0.418 (Windows)
    Feb-27 4:08:42 PM Starting Plug-In Initializing plugin weatherXML ...
    Feb-27 4:08:42 PM Error Initializing plug-in(2): weatherXML Instance::Object reference not set to an instance of an object.STACK: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
    Is the Enable button showing the green button for weatherXML? If so, click that and wait for it change to the red button. Then click to start the plugin.
    If you continue to get errors you might want to grab a backup of the ini files in the HS3/config/weatherXML directory and replace the current ones with the backups.
    Jeff Farmer
    HS 3, HSPhone
