Edit \HTML\Temperatrue.asp and remove everything except three lines. The first, and last which are the brackets and the one line starting with Response.Write
mcsTemperature Version 6
Did you look at this thread in the subforum http://board.homeseer.com/showthread.php?t=145967
Seems to be the same issue.
database issue?
I have set up xapmcs1wire -> mcsxap -> HS -> mcsTemperature. I see all the wanted 1wire device data in HS and have configured all sensors i want to collect data from in the Analog (1) tab in mcstemperature. I allso can see all these sensors in mcstemperature but all the graphs are empty as if there is no data available for my sensors in mcstemperature. I lurked around in some log files and found this:
mcsTemperature Debug | Log Temperature Sensor Count=12, INSERT INTO Sensors(SampleDate,F10,F11,F12,F13,F14,F1,F2,F3,F4,F5,F6,F7) SELECT #2011-02-16 19:54:14# AS QT,1000 AS Q0,2260 AS Q1,3300 AS Q2,-1580 AS Q3,9400 AS Q4,2,577361E+12 AS Q5,4210 AS Q6,2940 AS Q7,3170 AS Q8,2870 AS Q9,6810 AS Q10,1,54429E+07 AS Q11
mcsTemperature Debug | Log Temperature SQL Error Number of query values and destination fields are not the same. on line 950 Number of query values and destination fields are not the same.
mcsTemperature Debug | Change Field because , error number=0, Fields=F10,4,F11,4,F12,4,F13,5,F14,4,F1,12,F2,4,F3,4,F4,4,F5 ,4,F6,4,F7,11
mcsTemperature Debug | Log Temperature Retry SQL Error Number of query values and destination fields are not the same. on line 1010 Number of query values and destination fields are not the same.
mcsTemperature Debug | EvaluateDeviceAction DeviceActionCollection.Count=0, MonitoredEventCount=0
What can I do?
BR
Tomas
The problem is due to the comma in the scientific notation for F7
,1,54429E+07 AS Q11
Two quick suggestions. One is to look at F7's value as it does not look reasonable. The second is that here is a setting to map the decimal character. I forget exaclty where the mapping occurs as it may only apply to inputs and not database operations.
Also make certain you have the checkbox to save data to database at some periodic interval with the interval also specified. It is on the Interface Page of mcsTemperature.
removing 100% humidity measurements?
Is there some way to ignore or delete humidity measurements that are 100%? My humidity sensors work perfectly most of the time but for some reason the sensor gives the value 100% a few times (5-10 times) in a 24h period (288 measurement points). This makes the graph very ugly. My setup is xAPMce1wire -> McsxAP -> McsTemperature.
BR
Tomas
After I updated to 6.2.14 my virtual sensors are no longer updating, I have a straight line for all temp values since the update. My 1wire sensors work fine and I have the check box ticked to transfer virtual devices to database every one minute. The virtual devices are temp and set point readings from my z-wave thermostats. Any other setting I should review?
For specific issues a new thread should be started so that other will be able to find the information should others have a similiar problem.
The code to log data to the database is common for all items listed on the Sensor Page. The specific code is:
Code:620 If CalibrationDictionary.Exists(SensorDeviceCode(i)) Then 630 Data = Expression(CalibrationDictionary(SensorDeviceCode(i))) 640 hs.SetDeviceString SensorDeviceCode(i), FormatHTML(SensorFunctionType(i), Data) 650 Data = val(Data) * Scaling 660 hs.SetDeviceValue SensorDeviceCode(i), val(Data) 670 hs.SetDeviceLastChange SensorDeviceCode(i), Now 680 Else 690 sString = hs.DeviceString(SensorDeviceCode(i)) 700 If (SensorFunctionType(i) = jWindDirection) Or _ (SensorFunctionType(i) = jTemperature And OnlyTemperatureIcon) Or _ sString = "" Then 710 Data = CStr(CLng(hs.DeviceValue(SensorDeviceCode(i))) * CLng(Scaling)) 720 Else 730 Data = CStr(Round((CSng(MakeNumber(Trim(StripHTML(sString)))) * Scaling))) 740 End If 750 End If
There is debug output available in this section of the code that shows the SQL statement that is being used each time the data is logged. If the DeviceString/Value or Calibration considerations do not bear fruit then the general debug might help.
Graphs not displayed
Help needed,
I have just recently been moving my Homeseer installation to a new computer, and I have a problem with McsTemperature in order to chart my results.
System:
Windows 7 Pro 32 bit.
Interface: DS9490R
Version: 6.2.22
Problem:Things that I have done:
I setup an application in my IIS to verify that Chart Director are running and it works great all charts examples are displayed.
My 1-wire setup is working and the plug-in has found my devises and they are displayed correctly in HS.
Observations:
When I installed the plug-in the database did not install and I had to pull it from my old computer, could this be the root cause of the problem?
I have posted:
Database on http://www.daigaard.dk/mcstemp/mcsTemperature.mdb
Initfile on http://www.daigaard.dk/mcstemp/mcsTemperature.ini
Screen shoots: http://www.daigaard.dk/mcstemp/screen.pdf
Let me know if there is anything else that is needed to help me with this problem.
Regards
Daigaard
The message comes from there being no sensor data in your database. Your .ini file shows the following sensors being setup in the database, but the database has no sensors defined. Since the database was not created it is likely that the libraries that manage database operations are not present. If there are problems writing to the database then there should be some messages in the HS log to provide clues.
R1="s1-Wire_Garage,0,1"
R3="s1-Wire_Loft,0,1"
R4="s1-Wire_Ude_Temperatur,0,1"
R2="s1-Wire_Server_Room,0,1"
The .ini has the database located in the HS root folder, but the default is \Data. The location should not matter, but just letting you know in case you have two databases on your system.
The hyphen in the name is valid for database name, but it is also the same character used for subtraction. I tyipically try to avoid ambiguous characters in the names.
No data in the database
Hi Again,
I still have problems, I'm now at a point where I get the databases created.
I did change the naming of database labels but not change.
Latest findings:
If I delete the database, a new database is created in the Forecast Database location.
If I select the repair
and recreate it also creates the sensor table inside the database (same location for sensor and forecast). BUT no data are stored in the database. I expect that the database featurs are working since a table can be created??
Could you please assist on how to proceed.
Regards
Daigaard
