The house I own once had a wired security panel. At present, only the wires and sensors exist. I have traced out the different zones and door switches/wires. I have also found the horn circuit and have tested it and the horn sounds when power is applied to it.
I would like to tie the wires into HS somehow but I don't have a lot of cash to use for this product. Can something be purchased for under $100? I do have an arduino and a raspberry pi that I could allocate to this if a panel is too costly.
I am only looking to be able to arm/disarm using an on/off X10 switch and would like the alarm to flash all x10 lights if triggered as well as ring the wired alarm. I do have some X10 sirens that I could use rather than the wired alarm if it is too difficult to provide power to the wired alarm.
Can anyone help me out on this?
