Now getting this since changing my GSM Modem to a TP-Link MA-260
Everything seems to work OK
Any ideas?
Do you want logs?
Cheers
Scott
Oct-31 16:08:57 SMS-Gateway Error Error connecting: System.IO.IOException: The specified port does not exist. at MessagingToolkit.Core.Mobile.MobileGatewayFactory.Find() at MessagingToolkit.Core.MessageGateway`2.Find(C config) at HSPI_SMSGW.plugin.InitSMS() Oct-31 16:08:11 SMS-Gateway Error Error connecting: System.IO.IOException: The specified port does not exist. at MessagingToolkit.Core.Mobile.MobileGatewayFactory.Find() at MessagingToolkit.Core.MessageGateway`2.Find(C config) at HSPI_SMSGW.plugin.InitSMS() Oct-31 16:08:11 SMS-Gateway Error Error connecting: System.IO.IOException: The specified port does not exist. at MessagingToolkit.Core.Mobile.MobileGatewayFactory.Find() at MessagingToolkit.Core.MessageGateway`2.Find(C config) at HSPI_SMSGW.plugin.InitSMS() Oct-31 16:08:11 SMS-Gateway Error Error connecting: System.IO.IOException: The specified port does not exist. at MessagingToolkit.Core.Mobile.MobileGatewayFactory.Find() at MessagingToolkit.Core.MessageGateway`2.Find(C config) at HSPI_SMSGW.plugin.InitSMS() Oct-31 16:08:57 SMS-Gateway Error Error connecting: System.IO.IOException: The specified port does not exist. at MessagingToolkit.Core.Mobile.MobileGatewayFactory.Find() at MessagingToolkit.Core.MessageGateway`2.Find(C config) at HSPI_SMSGW.plugin.InitSMS() Oct-31 16:08:11 SMS-Gateway Error Error connecting: System.IO.IOException: The specified port does not exist. at MessagingToolkit.Core.Mobile.MobileGatewayFactory.Find() at MessagingToolkit.Core.MessageGateway`2.Find(C config) at HSPI_SMSGW.plugin.InitSMS() Oct-31 16:08:11 SMS-Gateway Error Error connecting: System.IO.IOException: The specified port does not exist. at MessagingToolkit.Core.Mobile.MobileGatewayFactory.Find() at MessagingToolkit.Core.MessageGateway`2.Find(C config) at HSPI_SMSGW.plugin.InitSMS() Oct-31 16:08:11 SMS-Gateway Error Error connecting: System.IO.IOException: The specified port does not exist. at MessagingToolkit.Core.Mobile.MobileGatewayFactory.Find() at MessagingToolkit.Core.MessageGateway`2.Find(C config) at HSPI_SMSGW.plugin.InitSMS()
I'm not sure I follow? I'm also not sure how high HS3 enumerates com ports to. Can you assign the TP-Link to a lower com port number and see if you can select that in HS3?
Sent from my iPad using Tapatalk HD
Looks like I might have found it. The TP-Link installer creates what looks like a virtual port (19) I think. There's an app that loaded from HKCU Run which I have deleted from the reg and it still works, but (so far) no error message.
So I think the app must have been fighting for the same port?!
I'll keep you posted
If I get a chance tomorrow, I'll try manually changing the ports to something lower.
